November 26, 2025, 01:00:50 AM *
Author Topic: Gauge relocation clamps  (Read 1438 times)
pancho
Bonanza Arkansas
« on: March 30, 2014, 08:43:29 AM »
Hey Guys, I am going to cut/mill some clamps from 1 X 1.75 aluminum stock to relocate the gauges in anticipation of receiving my Woodies. I am wondering if someone who has a set of the XF6 clamps could take a measurement from the bars to where the bend is on their clamps is to give me a starting point.
« Reply #1 on: March 30, 2014, 09:38:05 AM »
From the back of your clamp it is 5" to the up turn with 1" turned up.
The fX 6 relocation is a three piece clamp the clamp itself is 2 pieces and the the flat stock pice which the gauges mount to.
Also remember that you will need a longer speedo cable. But all other wiring and such is long enough stock.
pancho
Bonanza Arkansas
« Reply #2 on: March 30, 2014, 10:05:08 AM »
Thanks Bighead,,,, I dont quite understand,,, is the measurement five inches from the back of the bars to where it turns up??
« Reply #3 on: March 30, 2014, 10:09:02 AM »
This help?
« Last Edit: March 30, 2014, 10:10:46 AM by Bighead » Logged
pancho
Bonanza Arkansas
« Reply #4 on: March 30, 2014, 10:17:21 AM »
 I can get it from there,, .  Thanks brother
« Reply #5 on: March 30, 2014, 10:21:42 AM »
Post a picture of those dudes when you get them made.
« Last Edit: March 30, 2014, 10:37:01 AM by Bighead » Logged
pancho
Bonanza Arkansas
« Reply #6 on: March 30, 2014, 06:29:26 PM »
Cut out the blanks and milled the edges, then decided I needed to be riding today instead of messing around in the shop......
pancho
Bonanza Arkansas
« Reply #7 on: April 02, 2014, 04:54:21 PM »
Makin chips,,,, had time to put some holes in them.........  at this rate I will have them done about the time the faring comes in..
Can someone tell me how much longer the spedo cable needs to be when relocating the gauges to the handlebars and who has them.. other than XF6??
« Last Edit: April 02, 2014, 04:58:23 PM by pancho » Logged
« Reply #8 on: April 02, 2014, 07:45:32 PM »
Don't know who makes them or how much longer but they are quite a bit longer. I can't get to it to measure right now but if I remember tomorrow I will check it out for you.
Tailgate Tommy
Fort Collins, Colorado
« Reply #9 on: April 03, 2014, 04:50:42 AM »
Someone posted once that these guys make them in 6"-8"-10" workingclasschoppers on eBay. Sorry but I don't know the proper size. Search: speedometer cable extension 6" 8" 10" custom chopper speedo extended front end
pancho
Bonanza Arkansas
« Reply #10 on: April 16, 2014, 06:45:45 PM »
Well, I got the clamps done today,, here is what I ended up with. There are some machining marks I did not get completely filed out before polishing, but I felt I was spending entirely too much time on them and started to feel guilty as there are other things in the world that need doing........ Anywho,, I had the spedo off for measurements,, and after finishing the clamps, I put the spedo, windshield, and headlight back together and was going to go for a ride...
      Bike wont start... well first thing I think, it's the starter switch, it's always the starter switch. I take the switch out and apart, but cannot get the bike to crank even when jumping the terminals...!!  Well, I figure it must be in the headlight bucket as I had been messing with the wiring in there,, out comes the electrical tools and I get into the wiring. I had rewired the kill switch to use as the switch for my spots awhile back, so I take apart all the connections I made as I had not documented anything, and I found I did a pretty good job and had soldered everything and used good crimp connectors where appropriate,, everything looks good.. Now What,, did the bank sensor or starter relay go bad just setting here for the last couple of hours?? I start tracing starter voltage from the headlight bucket when it pops into my big brain that the neutral light is not on... DAH ....   OK, everything goes back together and I get to ride for a few miles.....      sweet       going to be cloudy and rain tomorrow.
jimmytee
Elizabethtown,KY
« Reply #11 on: April 16, 2014, 06:53:53 PM »
 cooldude Good job. Are you gonna make the longer speedometer cable and headlight bracket too??? 2funny I just paid the $199 for the kit when I did mine.
« Reply #12 on: April 16, 2014, 06:58:25 PM »
Look good Pancho  coolsmiley
pancho
Bonanza Arkansas
« Reply #13 on: April 16, 2014, 07:19:15 PM »
                           "I just paid the $199 for the kit when I did mine."
     I hear ya Jimmetee,,, I just thought these looked a little more substantial than the $200 ones,, plus they are custom.....   AND, that $200 can go into my tank while I'm runnin around Colorado.
« Reply #14 on: April 16, 2014, 09:03:43 PM »
You could sell those.   cooldude
jimmytee
Elizabethtown,KY
« Reply #15 on: April 17, 2014, 02:58:08 AM »
 cooldude They look nice
pancho
Bonanza Arkansas
« Reply #16 on: April 17, 2014, 05:41:45 AM »
Yeah, but I had a hard time putting in the time to make a set for myself....... to do it for money?? I just don't see it it BF.
Really looking forward to getting the faring in.... even though it will be a Tsukayu.
« Reply #17 on: April 17, 2014, 08:36:09 AM »
Looking forward to seeing plenty of pics.   Wink
