November 25, 2025, 11:52:13 PM
Front Brake Pins Hanger Stuck
Topic: Front Brake Pins Hanger Stuck (Read 861 times)
Mase
# 518
March 30, 2014, 07:01:41 PM »
The front brake pins are stuck pretty good. I have been using PBBlaster but have not used any heat. All I have is MAPP gas so I am not going to hit it with that. Would a heat gun work? The other bad thing is that over the years I have wobbled out the hole some to where none of the wrenches fit tight and want to walk out.
If I have to murder the pins I'm okay with that as long as I can find replacements before I take off on Thursday.
Any tips?
Last Edit: March 31, 2014, 06:28:45 AM by Mase
Re: Front Brake Pins Stuck
March 30, 2014, 09:24:32 PM »
When you get it out, don't install it very tight. It does not need to hold anything together. Use some Never Seize. If you have an impact driver, try that. A long allen wrench and a hammer might work.
March 31, 2014, 04:46:55 AM »
If you removed the calipers from the forks......put them back on, way more leverage that way
March 31, 2014, 05:06:21 AM »
If you round out the holes, remove the caliper and try vice grips on the pins inside the caliper where the pads are. Also a few good whacks with a hammer first to loosen things up.
da prez
Wilmot Wi
Re: Front Brake Pins Hanger Stuck
March 31, 2014, 07:22:29 AM »
Use a blunt metal punch that fits inside of the hole and give it a good sharp rap with a hammer. This method almost always works. There is a set of easy outs made by Roddick tools and some sold by Mac tools that are the best I have ever used. They are very short and work in the actual hole of the allen head.
da prez
=> InZane XXV
