April 29, 2026, 08:00:06 PM *
Author Topic: Daniel Meyer / Need your help  (Read 1897 times)
Mase
# 518
« on: March 31, 2014, 09:04:51 AM »
Daniel I have been working on my front brakes to make the bike safe for GOTF.  THe right side pin hanger is stuck and I drilled it and tried an extractor to get it out.  The extractor broke off in the head of the pin hanger.  I am taking the caliper off to be able to get to this hanger.  If you are around I would appreciate some help in getting this thing out of the caliper so I can install new pads and bleed the system.
I am sending you a PM with my cell.
Baron
Trophy Club, Texas
« Reply #1 on: March 31, 2014, 09:44:37 AM »
If you end up needing a right side caliper assembly I have one I bought on ebay and will let go for what I paid, $30.
Ride safe,
Baron
VRCC 28275
2000 Valkyrie Interstate
2023 Road Glide Limited
2022 KLR 650
Daniel Meyer
Moderator
The State of confusion.
« Reply #2 on: March 31, 2014, 10:12:27 AM »
Yah, Mase, responded to your PM...if you're talking the pin that holds the pads in, I'd go ahead and grab that other caliper from Baron...I don't have any spare parts that would apply and I'm not certain we could get the pin out if the extractor is stuck in there...it's hardened and can't be drilled...there may be ways...but it may tear up the caliper...would be good to have one ready...or just swap it and fix the other one if possible later...
CUAgain,
Daniel Meyer
RainMaker
Arlington, TX
« Reply #3 on: March 31, 2014, 02:01:55 PM »
I'd think that if you take the caliper off, you should be able to get a pair of vice grips on that pin and start it backing out.
2005 BMW R1200 GS
1981 GL1100I GoldWing
1972 CB500K1
« Reply #4 on: April 01, 2014, 09:21:28 AM »
Vice Grips and drill the pin out from the hex hole.  I tried to select a bit that was the same size as the pin and drilled mine out.  Only damaged a few of the threads, so it went well.
I pookie the shiznitz out of them every time I pull them off with antisieze.  That little black dust plug cover too.
Hay  Cool
Friendsville, TN, Troy, MI
« Reply #5 on: April 01, 2014, 09:31:06 AM »
Hay  Cool
Pookieing and Shiznitzing are both excellant PM practices.  I've personally found that applying copious amounts of mumpuck prior to assembly works wonders as well.
A damn fine bunch of professionals on this site!
Friendsville, TN - Troy, MI
Baron
Trophy Club, Texas
« Reply #6 on: April 02, 2014, 11:11:54 AM »
Marc,
Did you get the brake job done?
Ride safe,
Baron
VRCC 28275
2022 KLR 650
« Reply #7 on: April 02, 2014, 12:07:10 PM »
Hay  Cool
I am well versed in the redneck engineering terminology as pertains to the Valk.  What is this mumpuck of which you speak?  It must be like that elusive "snow" some of you northern guys talk about, right?
Hay  Cool
« Reply #8 on: April 02, 2014, 12:17:01 PM »
Jimmy, I think mumpuk is actually Obama BS that got discarded.
Flame suit on, flame away.
RainMaker
Arlington, TX
« Reply #9 on: April 02, 2014, 12:41:20 PM »
I didn't think any of the Obama BS got discarded - thought it got enacted! coolsmiley.
2005 BMW R1200 GS
1972 CB500K1
« Reply #10 on: April 02, 2014, 01:37:01 PM »
Kind sir:
That wasn't what I meant, but I like your version BETTER....
