November 26, 2025, 12:15:52 AM *
Author Topic: Where is this O-ring  (Read 997 times)
vmb
Mississippi
« on: April 01, 2014, 04:49:39 PM »
Just got my pinion cup off and according to the manual and the Partzilla diagram where the part was ordered there should be a large O-ring, part # 91359-MG9-003, (#35 on the diagram). I appears to go between the cup and the pinion retainer but that don't look right on the bike. Can one of you Valkyrie wizards please help? Thanks again Virgil in Mississippi
« Reply #1 on: April 01, 2014, 05:04:36 PM »
that o-ring must be inside......there is no o-ring to be seen or serviced whenever you yank the drive shaft out of the pinion cup.  I wouldnt worry about it
vmb
Mississippi
« Reply #2 on: April 01, 2014, 05:33:10 PM »
I appreciate that Chris. I can start putting this back together now!
YoungPUP
Valparaiso, In
« Reply #3 on: April 01, 2014, 05:34:56 PM »
Did you just pull the drive shaft for maintenance or remove the pinion cup from the final drive to replace it and the driveshaft due to failure?   If its was maint then then that oring isn't involved but if its replacement then....
99 STD (Under construction)
lee
Northeast Tennessee
« Reply #4 on: April 01, 2014, 06:34:32 PM »
The O-ring you are referring to (91359-MG9-003) goes on the outside of part (41331-MN5-000) #10 RETAINER, BEARING.
You don't need it even if you remove the Retainer.
You will not see this O-ring when removing the Pinion Cup.  It has nothing to do with the Pinion Cup.
Maby a picture will help.
« Last Edit: April 02, 2014, 04:40:18 PM by lee » Logged
Time is not what is taken but what remains.
C. Drewry
vmb
Mississippi
« Reply #5 on: April 01, 2014, 07:23:37 PM »
THIS BEGAN AS MAINTENENCE BUT I FOUND THE CUP BONE DRY AND WORN SO I AM REPLACING IT AND THE SHAFT. NEVER SUSPECTED ANYTHING BEFORE TEARING INTO IT. i JUST COULD NOT FIGURE OUT WHERE THE BIG ORING WENT
« Reply #6 on: April 02, 2014, 06:02:46 AM »
I removed a good pinion cup from a bad final drive and still saw no o-ring........
0leman
Klamath Falls, Or
« Reply #7 on: April 02, 2014, 08:33:36 AM »
I recently replace my pinion cup/drive shaft. I also got the O-ring you are mentioning.   When you take the pinion cup off, there is a retainer held in place by a screw(s).   Under this retainer is the O-Ring you are talking about.  My O-ring is still in the bag in my parts box.
vmb
Mississippi
« Reply #8 on: April 02, 2014, 02:13:57 PM »
Thanks Oleman, thats about what I had decided, leave it in the bag it came in. I appreciate all the input.
« Reply #9 on: April 02, 2014, 03:51:27 PM »
So the o-ring isn't needed?  Why did Honda put it there if there's no use for it?
pancho
Bonanza Arkansas
« Reply #10 on: April 02, 2014, 04:36:16 PM »
It's only needed if you tear into the final drive further than is necessary for changing the pinion cup......  The drawings are a bit misleading.
