November 11, 2025, 02:42:06 PM *
Author Topic: Desmog Kit  (Read 6099 times)
Chaosandconfusion
Tallahassee, FL
« on: April 07, 2014, 07:51:48 PM »
I saw a kit to do the desmog on this web page: http://www.xf6-custom.com/partpages/desmog.html. Although I think it is pricy at $65, I am wondering if it has everything I need to complete the job?
Ride Long and contemplate
« Reply #1 on: April 07, 2014, 08:41:30 PM »
Some quick setting JBWeld, new caps for the vacuum ports, and a hacksaw. That's all that's needed to desmog. Don't need to pull the tank and airbox until you're ready to at some more convenient time. A pair of 14" needle nose pliers helps also.
JetDriver
Columbus, OH
« Reply #2 on: April 07, 2014, 08:42:50 PM »
I think you've got a broken link.  XF6 is a long time supporter of this site, and a good guy.  Even without seeing your link, I'd say you can trust XF6.
« Reply #3 on: April 07, 2014, 09:03:54 PM »
Yep Daryl is a good fella. Give him a call he will talk with you and answer any of your questions.
Red Diamond
Beaumont, Texas
« Reply #4 on: April 07, 2014, 09:18:53 PM »
Don't create a lot of chaos and confusion for yourself, if it is running good leave it alone.
Bocephus
97 Valkyrie
Elizabethton, TN.
« Reply #5 on: April 08, 2014, 03:37:42 AM »
+1. If it ain't broke, don't fix it. Wink
« Reply #6 on: April 08, 2014, 08:21:23 AM »
I used two of those kits to desmog my interstates..... well Big BF did.
Pricy perhaps, but top quality product with everything you need (to remove everything unnecessary).
« Reply #7 on: April 08, 2014, 08:42:53 AM »
Alot of folks like Redeye's shiny desmog kit.
http://redeye.ecrater.com/p/8464393/shiny-desmog-kit-chrome-honda
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« Reply #8 on: April 08, 2014, 10:24:39 AM »
 cooldude cooldude
i used the one from Redeye , had everything and had great instructions w/ pictures.  i needed pictures uglystupid2
i think it was 45.00 follow BF's link.
or you could do as John says alot cheaper same results.
Wewa
If you please God it doesn't matter who you displease   but if you displease God it doesn't matter who you please Smiley
semper5
Flint, Michigan
« Reply #9 on: April 08, 2014, 06:14:37 PM »
I don't fully understand the benefits of desmogging. Can anyone break it down for a jarhead? Also, is there anything else to do once you desmog? I've heard about jetting the carbs, and I don't understand what that means too.
« Reply #10 on: April 08, 2014, 10:11:52 PM »
The desmog mostly removes a bunch of rubber vacuum hose that eventually wears, cracks, and leaks, thus degrading engine performance (barely noticeable at first, but getting worse over time), which causes you to have to tear into things to first find then fix.  It improves nothing from a perfect stock bike, but may come under the heading of long term preventative maintenance.  And our bikes (and rubber hoses) are aging.  It does not turn the bike into a polluter, but it removes crap that was not necessary to begin with.  It goes very well with replacing all large and small Orings in the intakes, and followed by a carb synch.  (and rebuilding or replacing the OE petcock, if necessary)
Modifying (or replacing OE carb parts) is for those who change exhaust, ignition, trigger wheel (needing bigger jets or other adjustment for more gas) or allow bad gas and inactivity to gum up the carbs (need new OE parts).
Both my bikes are desmogged with all new intake orings (rebuillt petcocks, synched), and both have untouched carbs as I run stock exhaust and ignition (one with a 4* IS Airlake wheel) and exercise great care in not letting corn/inactivity gum up my carbs.
« Last Edit: April 08, 2014, 10:13:24 PM by Jess from VA » Logged
PhredValk
Edmonton, Alberta, Canada
« Reply #11 on: April 08, 2014, 11:47:17 PM »
I just finished my desmog. I removed the smog gear from the top of the engine, put vacuum caps on the chrome pipes and epoxied the 6 hoses closed (California bike, extra stuff). Changed out the 'T' from no 6 carb (to some doo-dad under the tank) to a strait thru for the petcock and blocked off the tank vent to the canister. Cost me about $12.
I still have the Shiny Desmog Kit I bought, so if anyone wants it...
Fred.
« Last Edit: April 08, 2014, 11:49:44 PM by PhredValk » Logged
VRCCDS0237
NDFRC
Orange Park FL
« Reply #12 on: May 29, 2014, 05:50:30 AM »
having trouble locating the redeye shiny desmog kit.. cant seem to order from the website, cant find any on ebay.. what am i doing wrong?
« Reply #13 on: May 29, 2014, 06:50:29 AM »
I think somebody posted the other day that he was closed temporarily while moving his mom across country.
Farther
Quimper Peninsula, WA
« Reply #14 on: May 29, 2014, 06:50:51 AM »
 This link may help:  www.redeye.ecrater.com/
~Farther
NDFRC
Orange Park FL
« Reply #15 on: May 29, 2014, 07:14:16 AM »
yes i can get there but all products say xhold.. cant order, i sent him an email perhaps that will work.. thanks!
NDFRC
Orange Park FL
« Reply #16 on: May 31, 2014, 11:15:00 AM »
Okay, am all set, read and re-read everything to do with de-smog and it doesn't seem so bad now, so.. next project will be tank off, new pingle, ca-de-smog, air filter and intake o-rings, i think the part that will be challenging will be getting the airbox back on, oh well, cant learn it if ya don't do it.
I do appreciate all the feedback, there are a good group of folks on this forum.
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« Reply #17 on: June 20, 2014, 08:11:05 AM »
I just used zip ties on the air box.   Put 2 ties together and put it over one tube on the left and the tube across on the right, tighten the zip ties to pull the tubes towards the center.
Do that 2 more times on the remaining tubes and it will go back in easily.
Once back in just cut the zip ties ...   Wallahh
dan7uk
Louisville, Kentucky
« Reply #18 on: June 21, 2014, 05:50:38 AM »
Led
Wisconsin
« Reply #19 on: June 23, 2014, 12:39:44 PM »
I no longer remember which kit I used.  But I did it first thing!!  Sure cleaned up the engine, and She runs GREAT!!!
nogrey
Nampa, Idaho
« Reply #20 on: June 23, 2014, 01:37:29 PM »
Not sure if you've decided yay or nay on the desmog. I have worked on several Valks for friends and it's one of the first things I do when I suspect a vacuum leak that I can't find easily. Granted, so far as I know, the problems that I am looking at have only been related to the pair valves inasmuch as they are linked by rubber that is growing old and cracking. When I go into a valk, I just dive in and remove the carb bank, yank all the rubber crap out (except the petcock line if they have one), and remove the pair valves and smog stuff. I always have a couple of Rich's cheap desmog kits on hand (I think they're $5), but sometimes will use the JB weld/hacksaw method with the same results.
For me, I just want the peace of mind that comes with having as little a chance of a vacuum leak as possible.
Hajya
Tucson, Arizona
« Reply #21 on: June 24, 2014, 07:38:30 AM »
This link worked for me...
Current Rides:
1998 Valkyrie
2014 Triumph Rocket III
« Reply #22 on: June 24, 2014, 10:11:19 AM »
Darryl (sp) at 'xf6' is a good person, and a great guy to answer your questions.      I have bought some parts from him for my old 44 Harley and also for MGM.       Good service, and excellent quality  parts.     NO made in China crap.
berdoobuck
« Reply #23 on: June 24, 2014, 09:53:21 PM »
What I did -- pulled out all the rubber tubing and stuff, leaving just the metal tubes.  Bought six vacuum caps at Autozone, about two bucks with tax.  Placed the caps over the ends of the pipes.  Voila, no vacuum leaks.  The 14" curved tip needlenose pliers were very useful, but to access under the tank I took off the right rear carburetor intake pipe, so I could get my paws under the tank and work.  Did the job.  Better performance, got rid of the clacking sound that comes from rubber that has cracked. coolsmiley
Hajya
Tucson, Arizona
« Reply #24 on: June 30, 2014, 12:08:02 PM »
I apologize for my ignorance in advance. I have never done a desmog before and had never heard of it until I joined this awesome site.   Cheesy
I have been looking at two desmog kits:
and
They look completely different to me. The one from Redeye appears to have more rubber short hoses and I from what I have read on this site, I thought the goal was to eliminate the rubber to prevent vacuum leaks.
So my question is which one is better? I don't mind buying or installing either, but I want one for the long term so I don't have to do it again. Also, I want it to look the best that it can. I have my bike all dressed out.
I appreciate everyone's help...   cooldude
Hajya
Current Rides:
1998 Valkyrie
« Reply #25 on: June 30, 2014, 02:06:11 PM »
I'm not sure one is better than the other, but I've used the Redeye kit three times.
My rides:
Farther
« Reply #26 on: June 30, 2014, 03:10:39 PM »
I think both kits are very good but if your goal is to eliminate rubber then go with the FX6 one.
~Farther
wingrider02
Maple Lake, MN
« Reply #27 on: June 30, 2014, 06:46:39 PM »
I just installed the Redeye shiny kit, and the only hoses he uses are for plugs....there are three total...  Very nice kit, and great instructions.
« Reply #28 on: June 30, 2014, 07:24:21 PM »
I don't think you understand.  They both do away with the same amount of rubber.  One also replaces some of the rubber that will remain.
Hajya
Tucson, Arizona
« Reply #29 on: July 01, 2014, 06:15:27 AM »
Okay... I understand that... Of course there will always be some rubber left...  2funny
Current Rides:
1998 Valkyrie
cariduro24
« Reply #30 on: May 07, 2023, 06:41:15 PM »
Greetings, I know this is a very old thread but I'm in need of a desmog kit and I believe that Redeye is out of business, at least the product is out of stock. Can someone point me into other options to use as a desmog solution?
Ramie
2001 I/S St. Michael MN
« Reply #31 on: May 07, 2023, 07:52:32 PM »
Not the full kit like redeye used to sell but it works.
https://valkyriecarbsandcustom.com/ols/products/valkyrie-1500-desmog-kit
cariduro24
« Reply #32 on: May 09, 2023, 09:52:18 AM »
Thank you for the response! I looked at that one and it is out of stock as well. I'll continue looking and hopefully I'll find one.
Arcadio,
