November 26, 2025, 12:38:27 AM *
Author Topic: valve stems  (Read 872 times)
N0tac0p
« on: April 17, 2014, 04:21:33 AM »
just got my Jake wilson valve stems.  nice looking piece of hardware.
Question is what do you use for "locking" the nut in place?  I know you need to use a preparation agent of sorts for locktite when applying to stainless, these say chrome.
So what do my friendly valk owners advise?
pancho
Bonanza Arkansas
« Reply #1 on: April 17, 2014, 05:21:20 AM »
Never thought about using any kind of locking agent on them,,,,  just the tension caused by compression of the rubber grommet seems to be sufficient to hold things in place..??
« Reply #2 on: April 17, 2014, 05:26:29 AM »
 cooldude Never have had a problem.
My rides:
N0tac0p
« Reply #3 on: April 17, 2014, 05:59:41 AM »
so just tighten as far as it will go and be happy?
« Reply #4 on: April 17, 2014, 06:56:22 AM »
    Lightly snug. DO NOT over tighten. When the tire s are changed I check them over. They have NOT loosened up at al. RIDE SAFE.
Gideon
Indianapolis, IN.
« Reply #5 on: April 17, 2014, 12:36:09 PM »
Just tighten snugly, DO NOT over tighten, as previously stated.   cooldude
« Reply #6 on: April 17, 2014, 12:56:14 PM »
I recently found my front one to be leaking because I didn't tighten it
enough, and I had to pop the tire off the bead with a clamp and re-tighten
the valve stem.
I'm pretty sure you could tighten it enough to deform the grommet, and that
would be bad.
My leaker seemed OK at first, but I could spin the valve stem all the
way around pretty easily.
Now that it is tightened and leak-free, it does not spin (easily)...
« Reply #7 on: April 17, 2014, 02:39:23 PM »
Hopefully you got the ones that have the nut on the outside and the flange on the inside.  If these loosen up, you can snug it back down from the outside.  Smiley
Hay  Cool
pancho
Bonanza Arkansas
« Reply #8 on: April 17, 2014, 07:54:18 PM »
Yep, he got the jake Wilsons.... nut on the outside.
