February 08, 2026, 01:57:04 PM *
Author Topic: Drive Shaft Spring  (Read 1165 times)
vmb
Mississippi
« on: April 17, 2014, 03:31:13 PM »
Would someone out there please tell me how to remove the spring from the drive shaft. Special tool or what? I think its the only bump between me and getting back on the road. TIA Virgil
« Reply #1 on: April 17, 2014, 03:37:20 PM »
Well I did it the hard way, by pushing down on it with one hand and removing the clip with the other hand. But I wouldn't recommend that way, it was a bitch. Someone made a jig out of wood holding it in place. Try search under "driveshaft seal" maybe. Sorry not much help
vmb
Mississippi
« Reply #2 on: April 17, 2014, 03:58:47 PM »
Tried the same thing. U a better man than me if u got it. I'll check on the tip about the jig. Thanks. PS Is that annual party at Havasu Falls as crazy as it looks on TV or have u ever been. Just wondering
« Reply #3 on: April 17, 2014, 04:30:51 PM »
Two people: Hold shaft in a vice, spring end up. Use a hook tool (bend a flat screwdriver 90 deg) to pull down on the spring. The other guy uses an internal circlip pliers to squeeze the circlip. Good luck, yes it's a bitch. Swear words are often useful.
« Reply #4 on: April 17, 2014, 05:03:37 PM »
I don't know about being a better man crazy2, took me probably a dozen try's before I finally got it. And yeah this lake gets pretty crazy Evil. But they have cracked down on the nudity a little, I think do it for the revenue from fines and some of the old bastards around here can be pretty prudish  tickedoff
« Reply #5 on: April 17, 2014, 05:17:16 PM »
Wait till you try to get it back on...
Here's a wooden jig I threw together... slid the spring down over the
two screws and compressed the spring until I could fit the pinion
end of the shaft in front of the 2X2...
The computer I've posted all my pictures on, probably the first web
server in South Carolina, has passed on to that great bit-yard in the
sky... I've rehosted many of the pictures (I have them all) and edited
many of my VRCC posts so that the pictures aren't broken... I was looking
for this picture and noticed the "1500 wing final drive" post (5000+ hits) is broken,
I'll have to edit that one...
pancho
Bonanza Arkansas
« Reply #6 on: April 17, 2014, 06:49:47 PM »
Hey Mike,, couldn't you find some old raggedy scrap wood to make that jig out of??    HA
Looks like a knuckle saver..  good work.
jimmytee
Elizabethtown,KY
« Reply #7 on: April 18, 2014, 03:17:45 AM »
I was wondering why change it?
« Reply #8 on: April 18, 2014, 03:32:19 AM »
In my case, I had  a new drive shaft, but not a new spring...
pancho
Bonanza Arkansas
« Reply #9 on: April 18, 2014, 04:44:29 AM »
Or to replace the seal.
vmb
Mississippi
« Reply #10 on: April 18, 2014, 05:03:44 AM »
What's the term? YANKEE ENGINUITY! You guys come up with some outstanding ideas. I got it from here. And thanks. Virgil
« Reply #11 on: April 18, 2014, 08:18:56 AM »
Southern  Wink
0leman
Klamath Falls, Or
« Reply #12 on: April 19, 2014, 09:23:31 AM »
Like your jig for removing the clip.   I have just put my drive shaft in my vice,  used a vice grip pliers to push down the spring and then set the pliers to hold the spring down.  Didn't mar the surface of the shaft.  I have replaced two seals and traded spring and clips from old shaft to new shaft that way.
vmb
Mississippi
« Reply #13 on: April 20, 2014, 08:33:04 PM »
I stand corrected, SOUTHERN it is!
« Reply #14 on: April 21, 2014, 06:08:08 AM »
Southern   Wink
I saw that coming.   Grin
Brian
Monroe, NC
« Reply #15 on: April 23, 2014, 03:26:54 AM »
I compressed the spring using two or three nylon wire ties. It worked great and easy.  cooldude
