November 26, 2025, 12:40:53 AM *
Author Topic: Valve stem condition  (Read 1068 times)
weeder
Gillette , Wyoming
« on: April 24, 2014, 02:32:49 AM »
HONDA VALKYRIE cooldude
 Before I took my Valkyrie to the shop for tire change I ordered steel valve stems from Jake Wilson (thanks for the tip  VRCC)  I also ordered a valve stem driver ;
http://www.jakewilson.com/p/1753/13463/Slime-4-Way-Tool
After getting the bike home  I checked the valve stem front and back to check for tightness  with the tool and both  stems easily took another 1/3 turn before seating firmly.
Just a heads up ..
w
« Reply #1 on: April 24, 2014, 06:39:12 AM »
At least you got the Jake Wilsons that you can adjust from the OUTSIDE of the rim.  The first ones I installed had the nuts on the inside....  Sad
Good info!
Hay  Cool
weeder
Gillette , Wyoming
« Reply #2 on: April 24, 2014, 07:05:58 AM »
Jimmyt   did you put on or attempt to put the plastic stem keepers on?
 Mine  are off , see no need for them...
Joe Hummer
Arnold, MO
« Reply #3 on: April 24, 2014, 07:26:02 AM »
I would say you two are talking about two different things here.
The way I read the original post was that the valve stem valve (little insert into the valve stem) was loose by 1/3 turn.  This is supported by the indicated tool.  I am hoping that the valve stem nut wasn't loose by 1/3 turn...that would mean the shop had a hell of a time getting air in the tire...
Agreed on the supports...mine are off my bike.  The new stem does not need them.
Joe
1999 Valkyrie Interstate
« Reply #4 on: April 24, 2014, 07:35:20 AM »
Yes, judging by the tool pictured in the link he was talking about the valve CORE, not the stem.
weeder
Gillette , Wyoming
« Reply #5 on: April 25, 2014, 08:19:22 AM »
Ya 'valve core'  check
« Reply #6 on: April 25, 2014, 02:44:12 PM »
No, I don't have the "supports" on my 90 degree valve stems.  They are so solid that they are not needed.
Hay  Cool
97BLKVALK
VRCC#26021
Detroit Lakes, MN
« Reply #7 on: April 26, 2014, 07:04:40 AM »
What is the part number used for valve stem.  I purchased metal stem but they tighten from the inside and new tire will be mounted in a couple weeks and the idea of having access to checking the tightness is more than a bit interesting.  Smiley
Michael
1997 GL1500C - Black
1997 GL1500C - Purple
1997 GL1500C - Bumble Bee
1998 GL1500C - Blue and Cream
« Reply #8 on: April 26, 2014, 01:17:29 PM »
Sorry Michael, just saw this.
http://www.jakewilson.com/p/1753/19082/Myers-90%C2%B0-Tubeless-Chrome-Valve-Stem?term=90 degree valve stem
This is the ones I have bought with the nuts on the outside.
Hay  Cool
weeder
Gillette , Wyoming
« Reply #9 on: April 28, 2014, 11:58:59 AM »
Hay  Cool
Yes Jimmy T   that's the one I ordered,
