September 10, 2025, 04:20:50 PM *
Author Topic: Oil Drops under 98 Standard  (Read 1096 times)
Marinakorp
King of Prussia, PA
« on: April 25, 2014, 05:36:06 AM »
Went for a spirited ride to work, chilly (40 degrees or so) ...45 Miles mostly interstate @ 75 (ish) MPH.
When I stopped at work... I noticed a few Dime sized drops of oil under my motor...coming from around the cluster of rubber tubes...
I know... not much to go on...
I did not get a chance to inspect above and forward of this for a possible source... but any suggestions would be appreciated.
I would rather be judged by 12 than carried by 6
« Reply #1 on: April 25, 2014, 05:38:53 AM »
How often do you drain the dragon drool?  Thats in the area you describe...
Bagger John - #3785
« Reply #2 on: April 25, 2014, 06:08:25 AM »
Drain the vapor collection tube (use rubber gloves when doing this). Do you see water or oil pouring out?
If it's oil...remove the tank, open the airbox up and see if there is a buildup of oil residue inside. Should you find some, remove the airbox then investigate the smog plumbing. It sounds like you're getting oil vapor through the PAIR and air-cut valves, which is then condensing in the airbox and draining out.
« Reply #3 on: April 25, 2014, 06:51:57 AM »
Were the droppings from the right side or left side?  Right side probably "drool" as mentioned above. Left side could have been coolant overflow.   ???
My rides:
Marinakorp
King of Prussia, PA
« Reply #4 on: April 25, 2014, 07:02:53 AM »
Right Side.
If it is oil vapor... will a desmog fix this?
What is the down side to just cleaning this.. what is causing this...etc..
Lets assume it is the oil vapor in the PAir valves...what next?
Never Drained the Drool....
« Reply #5 on: April 25, 2014, 07:23:56 AM »
Right Side.
Thats a good way to get your air box, air filter and carbs gunked up...Ya gots to drain that drool!
« Reply #6 on: April 25, 2014, 07:33:54 AM »
AND if you do get oil from what appears to be the left side check the shifter shaft seal. Drain the snot/drool tube like others have mentioned. RIDE SAFE.
Marinakorp
King of Prussia, PA
« Reply #7 on: April 25, 2014, 07:55:19 AM »
Got that one last year... that you could smell as it hit the pipes.
This was different.
Thanks for the replies. Gonna drain the drool at lunch and go for a ride... I feel a sickness coming on...More of a vision problem.
I just don't see myself coming in for the rest of the day.....
Rio Wil
« Reply #8 on: April 25, 2014, 09:58:05 AM »
The drool tube normally has a plastic plug in it.......so if you have never drained the drool, is the plastic plug missing.  If its missing, the tube has been draining itself  and is in no need of draining.  If the plug is installed, why is it leaking now..... crazy2 crazy2
« Reply #9 on: April 25, 2014, 10:32:09 AM »
And if that plug is missing it needs to be replaced!
Drain the drool at least every couple of months.  Pair of pliers and a couple of minutes.  Don't do it on your clean concrete driveway.
« Reply #10 on: April 25, 2014, 11:43:18 AM »
maybe u parked where a HD was parked.   2funny 2funny
« Reply #11 on: April 25, 2014, 11:53:03 AM »
Those were my thoughts exactly when I first read this thread.   2funny   2funny   2funny
My rides:
Marinakorp
King of Prussia, PA
« Reply #12 on: April 25, 2014, 02:08:41 PM »
Looks like a slight overfill on the oil.
Drained the drool.
Checked the oil level and is even with the chrome dipsrick line. Should be slightly lower than this line.
« Reply #13 on: April 25, 2014, 04:44:22 PM »
Drained the drool.
A friend of mine that put 4 liters in instead of 4 qts had a leaking/dripping thing like you had, so overfill can cause it.
« Reply #14 on: April 26, 2014, 05:21:21 AM »
Drained the drool.
Good morning Chris! Not trying to get in an argument, but 4 liters should not be an overfill. One quart (US) is 0.9463...  liters.   ???   Am I looking at this wrong?
My rides:
Red Diamond
Beaumont, Texas
« Reply #15 on: April 26, 2014, 06:24:20 AM »
I just dump in 4 quarts, no problems. It calls for 3.75 - 3.90 quarts, 4 ounces won't hurt it. Besides, that much remain in the bottle after you dump it in.
« Reply #16 on: April 26, 2014, 06:29:47 AM »
Drained the drool.
I believe you are looking at it wrong.......I have always known a liter to be more than a qt........I have also been wrong before too
Wilburt
« Reply #17 on: April 26, 2014, 08:05:10 AM »
4 Liters = 4.22675 US Quarts
Joevalk
Santa Fe, Texas
« Reply #18 on: April 26, 2014, 09:16:16 AM »
Can I get a liter of cola? uglystupid2
VRCC#32720
1999 Grn/Silver Interstate
« Reply #19 on: April 26, 2014, 09:26:10 AM »
Drained the drool.
You're right Chris, I was a 180 out. 1.05688... qts in a liter
My rides:
