September 10, 2025, 04:21:56 PM *
Author Topic: Final drive flange  (Read 748 times)
ezchuck
« on: April 25, 2014, 06:58:27 PM »
My final drive flange is staying in the final drive and not letting me drop wheel any tricks on how to pry it out? Or am I doing something wrong?
« Reply #1 on: April 25, 2014, 07:19:54 PM »
I think the slot on the bottom of the black plastic ring is a
place to insert a pry tool (screwdriver or something) to work
the flange loose...
ezchuck
« Reply #2 on: April 25, 2014, 07:42:31 PM »
Thanks Mike Ill try it.
nogrey
Nampa, Idaho
« Reply #3 on: April 25, 2014, 08:37:02 PM »
Once you get it out, you need to replace the rubber dampness. They have worn and no longer hold the drive flange properly.
ezchuck
« Reply #4 on: April 26, 2014, 04:07:32 AM »
da prez
Wilmot Wi
« Reply #5 on: April 26, 2014, 05:13:08 AM »
  Loosen the four nuts on the final drive .  Check the procedure in shop talk as I have done it many times and even help others. They will pry apart. Do a thorough inspection when you get it down.
                   da prez
