April 29, 2026, 11:03:26 PM *
Author Topic: Eddie, any luck?  (Read 2426 times)
« on: April 27, 2014, 06:58:46 PM »
Wondering if you had a chance to work on your problem child....I'm talking about the Valkyrie now. 2funny
FloridaValkRyder
Apopka, Florida
« Reply #1 on: April 27, 2014, 07:09:13 PM »
Ohhh..thought you meant Kim beating up on poor unsuspecting bikers..... : Grin
I still miss her.
Tropic traveler
Silver Springs, Florida
« Reply #2 on: April 27, 2014, 07:33:10 PM »
Well not much but I did a bit more diag thanks to Bert who stopped by. While I kept it running via throttle control Bert checked pipe temp. We discovered that #4 AND #5 were not firing, pipes were cold. Just for the hell of it I bought 6 new plugs & replaced #4 & #5. No dice. Bert also pointed out that I had the petcock line run to #5 so I swapped it back to #6 like it should be.
Interestingly I shut the gas off & ran it until it started to shutdown a bit & it actually smoothed out just a little. A few minutes later I turned the gas back on to pull it back into the garage & for whatever reason the popping stopped but still no idle.
I guess my next move will be to pull the tank to check the coil wiring & just for fun I'm going to eliminate the extra inline fuel filter.
I do have a question, if I have the throttle cables adjusted out of whack can that cause the no idle & the manual idle knob to become non functional? It was several months between tear down & reassembly.  Embarrassed
« Last Edit: April 27, 2014, 07:34:41 PM by Tropic traveler » Logged
'13 F6B red for Kim
Bert AKA,Valkaholic
Back-N-Black
« Reply #3 on: April 28, 2014, 05:27:07 AM »
Hey Eddie I Don't Think That The Cables Would Interfere With The Idle Adjust Unless They Keep The Spool Where The Cables Are From Moving, But I Don't Think So. If The Coils Check Out You May Have A Bad Pick-Up At The Timing Wheel, But I Would Make Sure That The Coils And The ECM Are Working Properly First Before Digging Into The Trigger Wheel Pick-Ups.
IamGCW
727 hood
« Reply #4 on: April 28, 2014, 05:32:20 AM »
Eddie
You may want to read this thread from the Tech section.  Near the end is some interesting looking crud he got out of the carb.
Gil
http://www.valkyrieforum.com/bbs/index.php/topic,65925.0.html
Gil
« Reply #5 on: April 28, 2014, 06:03:25 AM »
It can have an effect on the idle knob, found that out myself while working on the rebuild I did a couple years ago. Since then when I have to remove those cables, I mark the shafts where the nuts are with a Sharpie so I can get an approximate setting when I reinstall. Always loosen them at the top before removal. I doubt it would have an effect on idle, if it did it would affect all the cylinders. Strange that #4 & 5 weren't firing, they're on opposite sides and different coils. I'll have to check the schematic to see which trigger wheel pickup is involved.
Thunderbolt
Worthington Springs FL.
« Reply #6 on: April 28, 2014, 03:32:24 PM »
I try to mark the cables also.  I also put an O for outside and an I for inside on the two cables.  Eddie as John mentioned #4 and #5 are on separate coils.  Do you have one of the old spark plug testers kind of like a 12V test light to check it for firing? You could also hold the plug onto a good ground and look for spark.  More dangerous though.  If the plugs have been changed and the spark plug is firing it must not be getting gasoline if those cylinders were cold at the exhaust.  I know I am beating the proverbial dead horse but there can be fuel in the bowl and if the jet is clogged again the fuel won't be pulled into the mix so no kaboom.
« Last Edit: April 28, 2014, 03:36:42 PM by Thunderbolt » Logged
James III
Tampa, Florida
« Reply #7 on: April 28, 2014, 04:19:11 PM »
Eddie, I left you a PM with my phone number....I have an idea to check for you but hard for me to write out.
James
James
« Reply #8 on: April 28, 2014, 05:14:45 PM »
Here's any easy way to check for spark; stick a small bolt in the plug cap and hold it. If you hair stands on end and you pee down your leg....yep, got voltage there.  2funny 2funny
FloridaValkRyder
Apopka, Florida
« Reply #9 on: April 29, 2014, 03:54:34 PM »
All righty then...we may need to find another way to do that....Why not just stick your tongue in the spark plug cap.  Grin
I still miss her.
IamGCW
727 hood
« Reply #10 on: May 04, 2014, 01:38:48 PM »
Any updates on this?
Gil
Tropic traveler
« Reply #11 on: May 04, 2014, 03:09:50 PM »
Haven't got back on it yet. Six hours running the pressure washer today... I'm too sore to do anything right now.  Shocked Shocked
I'll probably hit it a lick tomorrow!
'13 F6B red for Kim
« Reply #12 on: May 12, 2014, 07:02:14 PM »
Wanted to bump this back to the top. So Edward, whassup?  Cheesy
James III
Tampa, Florida
« Reply #13 on: May 12, 2014, 07:17:46 PM »
 Wink Agree with John says, what's the scoop...? Any further speculations?
James
James
Tropic traveler
« Reply #14 on: May 15, 2014, 07:48:46 PM »
Cranked it back up again tonight just for the hell of it.
It will idle with the "choke" fully engaged. Still runs poorly, popping & missing until WOT.
Ran it with the gas cap popped open, no change. Pulled a couple wires, #4 & 6 & they both are firing. Still absolutely will NOT idle unless choke fully engaged.
Still stumped.
Been very busy working on the house & property. We got a larger than anticipated tax refund & I vowed to spend it all on much needed improvements. I still have a lot of privacy fence to replace along with fixing the ceiling in the Valkyrie garage. Somewhere in between I will get back on the '97 issues.  Wink
'13 F6B red for Kim
« Reply #15 on: May 15, 2014, 08:04:14 PM »
No idle without the choke sure smacks of clogged slow jets. I know you're looking forward to pulling the carbs again.  Angry
Tropic traveler
« Reply #16 on: May 15, 2014, 08:20:47 PM »
I'm afraid you may be right.  Sad Angry
'13 F6B red for Kim
