November 26, 2025, 01:26:13 AM
Brighter NEUTRAL-TURN-HIGH BEAM Bulbs???
Topic: Brighter NEUTRAL-TURN-HIGH BEAM Bulbs??? (Read 772 times)
Jetflyer
Vale, North Carolina
May 03, 2014, 12:38:46 PM »
Does anyone have a brighter bulb solution or modification for the NEUTRAL-TURN- HIGH BEAM cluster of bulbs on the headlamp, so they can be seen better in full sunlight?
Last Edit: May 03, 2014, 12:42:18 PM by Jetflyer
I'm either driving a Valkyrie or an Airbus... it just depends on the day of the week.
big poppa pump
San Antonio, TX
Re: Brighter NEUTRAL-TURN-HIGH BEAM Bulbs???
May 03, 2014, 12:44:27 PM »
Installed LED's from superbrightLED's. Much much brighter.
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
Bone
May 03, 2014, 12:54:56 PM »
Here's a link to a post from 2011. With Comparison pics with LED bulbs.
http://www.valkyrieforum.com/bbs/index.php/topic,34551.0.html
BobB
May 03, 2014, 02:03:35 PM »
Here is another post from chrise2496 that has the information you are looking for:
http://www.valkyrieforum.com/bbs/index.php/topic,35394.0.html
I met Chris at Inzane XII, and after seeing his indicator bulbs, particularly the turn signal indicator, I just had to make the same mods he had done. I believe that I modified the wiring harness in a different manner but all the same result. Chris is a real electrical techie and an asset to this group.
Andy Cote
Windham, Maine
May 03, 2014, 03:05:03 PM »
Here's a solution from the famous Mark T.
http://horseapple.com/Valkyrie/Tech_Tips/Improving_Indicator_Light_Visi/improving_indicator_light_visi.html
2015 Goldwing, basic black
Previously: 2000 Valkyrie Interstate, 1997 Valkyrie Standard, 1988 GL1500, GL1200 Standard, GL1200 Interstate and many other Hondas
Jetflyer
May 03, 2014, 09:18:22 PM »
Thanks guys!
I have decided to try the superbright LED's and the Kuryakyn diode kit.
=> InZane XXV
