January 29, 2026, 04:46:13 PM *
Author Topic: Blowing turn signal bulbs...  (Read 3602 times)
Printer Mike
Eatonton, Georgia
« on: August 01, 2009, 10:31:00 PM »
My "new to me" Valk is blowing the right front turn signal bulb. The first day I rode it, the bulb burned out after several hours of riding..."No big deal," I thought.....Wheeled into an auto parts store, bought a 2 pack, replaced the bulb...signal worked again, put the spare in the bag, and all was good again.
Then, today, it blew again. So I replaced it, hoping that maybe it was just a coincidence.....NOT! Blew again after just a few uses.
Any ideas? I ran a search on this, but came up empty.
Thanks for any help!
Never give up!
« Reply #1 on: August 01, 2009, 10:38:56 PM »
Is there any other wiring attached to your turn signals? Highway lights on the running circuit, extra turn lights? Check all the added wires.
Printer Mike
Eatonton, Georgia
« Reply #2 on: August 01, 2009, 11:00:11 PM »
No additional turn signals, but there are highway lights...the turn signals hang down/are attached to the highway lights.
It may be my imagination, but the right turn signal(the one that keeps blowing) seems to be a tad brighter than the left.
Never give up!
« Reply #3 on: August 02, 2009, 05:07:09 AM »
Any chance water is getting on the bulb?
Gilligan
Gilligan and Navigator - Wherever we ended up
Southwest Indiana
« Reply #4 on: August 02, 2009, 06:00:05 AM »
Check the rating of the bulb your using against the rating in the Valk service manual.  You might have the wrong one in there.
The service manual says the following:
1. For GL1500C/GL1500CT, use 12-V 32/3 cp X 2
2. For GL1500CF, use 12-V 35/2.8 cp X 2.
I have a 1999 Interstate (GL1500CF) and I never found a bulb with the above rating, but I use a 12V - 21/5W bulb for the frunt turn signal/ running light (Honda Part 34906-447-711). In over 10 years and over 88,000 miles, I just replaced the left one. I replaced the right one last year.
I hope this helps.  Ride Safe.
Two-up Touring for 10 yrs on a 1999 Valkyrie Interstate
48 U.S. States - 5 Canadian Provinces - 1 Mexican State
« Reply #5 on: August 02, 2009, 09:03:57 AM »
Be sure to check any wiring that was modified to mount the highway lights. My guess is you have a poor insulator that is vibrating and occassionally touches ground.
Printer Mike
Eatonton, Georgia
« Reply #6 on: August 02, 2009, 12:32:40 PM »
Everything looks dry in the bulb socket. I'll check the bulb ratings and wiring.
Kind of a bummer....I wanted to ride a while before I worked on it. But, might as well get my feet wet...lol...
Thanks for the tips!
Never give up!
NCGhostrider
Jacksboro, TX
« Reply #7 on: August 02, 2009, 09:04:01 PM »
I wonder if something is "grounding" thru it.  I have seen weird things on trailers and older cars where a shorted wire would cause the nearest path to ground to be thru a bulb.  Its hard on them if they are carrying more load than the wattage they are rated for... kinda like a fuse in a circuit in this case..
Just my 2 cents worth..
Craig
NCGhostrider
99 I/S
99 I/S
Madmike
Campbell River BC, Canada
« Reply #8 on: August 03, 2009, 10:10:05 AM »
Do any of the other lights change in brightness or intensity when you use the right side turn signal???  Does it look like they blink in synchronisation with the turn signal???
Printer Mike
Eatonton, Georgia
« Reply #9 on: August 04, 2009, 09:33:50 PM »
OK....I think I found the problem. There were "1154" bulbs in the front turn signal / running lights. Those are 6 volt bulbs!
So, I just replaced them both with 12 volt bulbs. I still need to check the rear ones.
Thanks very much for all the help and tips! cooldude
I guess this is just part of buying a used bike. I'm going to check everything I can think of on this bike before my road trip in September.
Never give up!
Madmike
« Reply #10 on: August 04, 2009, 10:12:53 PM »
http://www.valkyrienorway.com/partlist.html
there are a couple of places that you can get the spares list crossovers including the link above
Printer Mike
Eatonton, Georgia
« Reply #11 on: August 04, 2009, 10:39:46 PM »
Thanks for that link! cooldude Just what I needed...
Never give up!
Mr.BubblesVRCCDS0008
« Reply #12 on: August 05, 2009, 01:38:55 AM »
if you want brighter turn signsls use a 3496 bulb.
Bladedog
Lompoc, CA (Central Coast)
« Reply #13 on: September 16, 2009, 10:45:33 AM »
Is this a good replacement for BOTH front AND rear?  Isn't this also the same bulb for the tail/brake light?
It's easier to get forgiveness than permission.
Thunderbolt
Worthington Springs FL.
« Reply #14 on: September 16, 2009, 06:07:36 PM »
brake/running light on a standard or tourer.  Running is the same candlepower as the 1157.  I don't think it can be used on the turnsignals.  Could be wrong.
Kingbee
VRCC# 576
Northern Illinois
« Reply #15 on: September 17, 2009, 05:07:11 AM »
I use it on the turn signals with the Kury bezels, and it's noticeably brighter, as caught here with my 4-way flashers, as only my left one has the bulb and bezel installed for the PIC.
The single filament version for the rear is 3497, and the difference is just as dramatic
1999 Interstate
2000 Interstate
2004 Rune
