January 29, 2026, 07:02:11 AM *
Author Topic: Mounting Stebel Nautilus Horn  (Read 3713 times)
valk2128
Suwanee, GA
« on: August 02, 2009, 06:40:51 AM »
I am in the process of replacing the dead stock horn with a Stebel Nautilus on my 1998 Valkyrie Standard.
Where and how did you mount your Stebel Nautilus horn?
Thanks for the help.
« Last Edit: August 02, 2009, 06:43:12 AM by valk2128 » Logged
Kidd
Sedona
« Reply #1 on: August 02, 2009, 06:52:33 AM »
http://www.valkyrieforum.com/bbs/index.php/topic,6732.0.html
« Reply #2 on: August 02, 2009, 03:22:29 PM »
Looks purdy good here, if its chrome.  Requires a fabricated bracket, easy to do.  Hoser  cooldude
mooserider
Blue Knights TX6, Ride with Pride
La Porte, Tx
« Reply #3 on: August 02, 2009, 05:24:55 PM »
I mounted mine in the stock horn location, I think it looks great there. It blends in with the chrome on the engine.
« Last Edit: August 02, 2009, 05:27:35 PM by mooserider » Logged
Ride with Pride
Spirited-6
Nicholasville, Ky.
« Reply #4 on: August 03, 2009, 02:01:01 PM »
I also put mine in orgin. place. Put relay behind neck cover. Used alum. to make bracket to mount. On for several months, works fine.
Spirited-6
BonS
Blue Springs, MO
« Reply #5 on: August 03, 2009, 03:14:16 PM »
I mounted my Chrome Wolo/stebel very much like Hoser's but a little more forward. I have a pingle and really didn't like the gaping hole that remained after removing the stock petcock chrome. It mostly covers the black engine hanger and leaves enough room to manipulate the Pingle and bleed the clutch.
« Last Edit: August 03, 2009, 07:32:02 PM by BonS » Logged
