February 08, 2026, 05:32:25 PM
intake manifold o rings on 97 valkyrie
Topic: intake manifold o rings on 97 valkyrie (Read 2586 times)
blackvalkyrie
California
May 14, 2014, 11:01:33 AM »
I need to replace my o rings on my intake manifolds as they are leaking badly. Two questions:
1) do i need to use a sealant on the o rings or just install them
2) will i have to do any carb adjustments or just fire her up and go?
Many thanks
big poppa pump
San Antonio, TX
Re: intake manifold o rings on 97 valkyrie
May 14, 2014, 11:05:36 AM »
- No sealant required. Just replace old with new. I used very small amount of grease on the o-rings to make sure they stay in place.
- Replace and ride.
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
May 14, 2014, 11:53:47 AM »
Don't use any sealant. Just grease to hold in place as mentioned.
You shouldn't have to make any adjustments, unless, adjustments were made while some were leaking.
May 14, 2014, 04:14:05 PM »
OK Here's the upgrade. Use a #123 O ring in Viton or silicone. Don't buy OEM from Honda. My Vitons are several years old and haven't ever leaked.
blackvalkyrie
California
May 15, 2014, 08:10:20 AM »
Thank you
Quote from: big poppa pump on May 14, 2014, 11:05:36 AM
- Replace and ride.
blackvalkyrie
California
May 15, 2014, 08:12:58 AM »
Thanks for the info, but I already bought the oem rings...my bike has 75K on it..so at this point i'll ride it and then next time get those rings you mentioned... happy riding
Quote from: sandy on May 14, 2014, 04:14:05 PM
blackvalkyrie
California
Reply #6 on:
May 15, 2014, 08:14:49 AM »
Quote from: Patrick on May 14, 2014, 11:53:47 AM
Reply #7 on:
May 15, 2014, 09:41:25 AM »
when your intakes are off is an excellent time to feel around back in there
for rotted vacuum and carb drain lines
Reply #8 on:
May 15, 2014, 09:42:16 AM »
Yeah, I think you're right!
My OEM O-rings only lasted 12 years.
Cheap crap.
blackvalkyrie
California
Reply #9 on:
May 16, 2014, 09:21:50 PM »
good idea! thanks
Quote from: hubcapsc on May 15, 2014, 09:41:25 AM
blackvalkyrie
California
Reply #10 on:
May 16, 2014, 09:23:17 PM »
LOL
Quote from: Ricky-D on May 15, 2014, 09:42:16 AM
Cheap crap.
