November 13, 2025, 02:23:49 PM *
Author Topic: Using Plastifix from Urethanesupply.com  (Read 1768 times)
« on: May 15, 2014, 05:48:31 PM »
I also posted this on the General board, some folks hardly ever look in both places. I have an '84 GL1200 Std. restoration project that I'm currently working on. It has a plastic radiator shroud at the top and bottom of the radiator and the mounting holes for it are damaged. One is cracked the other broken off, so I was directed to the following video which might come in handy when fixing the tabs on the side panels of our Valks.
Create New Tab On Motorcycle Fairingpowered by Aeva
« Last Edit: May 15, 2014, 06:01:13 PM by John Schmidt » Logged
donaldcc
Palm Desert, CA
« Reply #1 on: May 15, 2014, 06:25:27 PM »
  john, I have this Plast-aid that works great.  I recently had riding friend here and was able to repair shield on helmet until he got home.  very strong bond that can be molded.  check it out.  good for every garage.
http://www.plast-aid.com/
Don
springbok53
Michigan
« Reply #2 on: May 16, 2014, 09:00:06 AM »
Wow.  Two great products that I had no idea existed.  Now I can repair any number of things that I was ready to give up on.  Thanks, guys.
Some days the best part of the job is that my chair spins
97Valk_CT_Euless
Euless Tx
« Reply #3 on: May 16, 2014, 10:39:42 AM »
Does anyone have a list of the plastics that Past-aid will bond to?  I couldn't find it on the website.  So far it hasn't stuck to either my phone clip or the intake duct I tried to fix with it.  So far it makes a really cool plastic marble... But the marble bounces like crazy!
« Reply #4 on: May 16, 2014, 05:19:07 PM »
I knew I heard of this stuff before, but I think there was even an older one. I was looking for the crack repair they had a video of.
http://www.valkyrieforum.com/bbs/index.php/topic,55975.0.html
Then there is this info on basics for plastic repair I kept the link for.
http://faq.ninja250.org/wiki/Plastics_repair_with_ABS_cement
Found it. It was my post in the HSATF, which was actually linked to from here by another member back in July 2011.
http://hondashadowacetourer.yuku.com/topic/13392#.U3artZ3n_IU
« Last Edit: May 16, 2014, 05:23:37 PM by gordonv » Logged
97Valk_CT_Euless
Euless Tx
« Reply #5 on: May 17, 2014, 08:01:06 AM »
Ok, I feel stupid.  It helps to loke at the BACK of the instructions too...
Plast-aid is good on (Chemically binds to): acrylic, ABS, Polycarbonate, PVC, styrene.  Mechanically binds to rough/porous surfaces (i.e. wood etc).
Does NOT bond to polyethylene, nylon or rubber.  My phone and the intake housing were probably poly.
donaldcc
Palm Desert, CA
« Reply #6 on: May 17, 2014, 11:36:25 AM »
It helps to look at the BACK of the instructions too...
 Grin Grin
Don
« Reply #7 on: October 11, 2019, 04:47:36 AM »
Just happened to revisit this post in my bookmarks and I came across another super cheap repair.  Super glue and baking soda.  I bought a very neglected IS with a busted right radiator pod (the top two screws that hold the rear panel on place had been ripped completely out and the plastic pieces were gone.  I was able to build up the void with super glue and baking soda and then shape it with my Dremel tool.  I haven't painted it yet, but also used this to replace some pulled out brass inserts in the fairing and fill holes in the pods.  I plan to use it to rebuild a broken tab on the center cover and patch some holes drilled in the trunk.  There are several videos on youtube that you can watch to see the process.  I'll try and post some pics of the pod repair if I get a chance.
You can buy super glue 2 tubes for a buck at the dollar store and BS is probably in your kitchen cabinet.  I plan to carry a little of each on the bike for emergency repairs.
john_berry
« Reply #8 on: October 11, 2019, 07:37:50 AM »
I suggest SEM 50 for plastic. It's amazing.
pocket aces
Tampa, Fl
« Reply #9 on: October 11, 2019, 09:39:37 AM »
Which SEM 50 product did you use? I want to fix my pods. The Baker air wings cracked and broke off a little piece of my pods.
john_berry
« Reply #10 on: October 11, 2019, 11:48:27 AM »
I like the 40507 because it starts to set in about 45 seconds. It's the best I have found for repairing plastic. I've even used it to replace broken plastic thread bosses with success.
Gnarly
FlyinJenni2
Resume Speed,KY
« Reply #11 on: October 11, 2019, 12:24:39 PM »
Not directly related to plastics repair, but someone may find this helpful.
It's like an online tool for adhesive advice, and it's almost too simple to use.
http://www.thistothat.com/
I've loved many bikes, over the last 52 years of riding, but this Valkyrie machine may have propelled me headlong into IDOLATRY....
