February 08, 2026, 05:32:57 PM
06 VTX 1300 fluid change questions
Topic: 06 VTX 1300 fluid change questions (Read 1040 times)
May 16, 2014, 10:38:04 AM »
Buddy bought a bike that was already 'serviced'. Well it wasnt, so he is doing it all now prior to prime riding season. How do you do the coolant change? Obv its different from the valks as no radiator cap, etc.
Also seems to be very cold blooded as its needing a choke alot of the time. Any thing to check? Seem to start better once the plugs were changed. Gonna run a few tanks of a carb cleaner thru it.
17k on the odo.
big poppa pump
San Antonio, TX
Re: 06 VTX 1300 fluid change questions
May 16, 2014, 10:41:30 AM »
Coolant change should be the same as any water cooled bike. Radiator cap should be under the gas tank. You'll need to move the gas tank back to get access to the radiator cap.
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
May 16, 2014, 10:57:53 AM »
Quote from: big poppa pump on May 16, 2014, 10:41:30 AM
So there is a rad cap under the tank? There is one under the left side cover that we 'think' goes to the reservoir tank.
big poppa pump
San Antonio, TX
May 16, 2014, 12:22:02 PM »
Yes, there is one underneath the tank. The tank needs to be removed or pulled back and lifted enough to gain clearance to the radiator cap.
VRCC#35870
VRCCDS#0266
May 16, 2014, 12:23:27 PM »
Having a shop manual is always a good idea; also there are MANY bike-specific websites with lots of good info.
May 16, 2014, 04:13:25 PM »
Quote from: Jess from VA on May 16, 2014, 12:23:27 PM
he just got it so havent had time to get a manual. I knew there were vtx owners here so by default i asked here first.
PAVALKER
Pittsburgh, Pa
Reply #6 on:
May 16, 2014, 08:48:37 PM »
Yep.... Res tank under side cover. Rad cap under tank on right side I believe. A 2x4 scrap should do the trick to hold the tank up while servicing the fluids. Make sure to clean the cap off inside and to blip the throttle to get air bubbles up and out.
John
