November 26, 2025, 01:58:50 AM *
Author Topic: Removing entire Rear fender  (Read 948 times)
QUIETMAN
Wexford, Ireland
« on: May 26, 2014, 11:13:56 AM »
Howdy all,
My Standard is going for paint very shortly and I'm stripping it myself, front fender and tank will be handy.
Looking at the rear fender and yeah it's in 2 pieces, rear bit I understand I have to disconect lights etc from the wiring harness but can't see anything on the front section of the rear fender ? I'm gathering the side rails etc will have to come off ?
Any advice is much appreciated.
Cheers
Quietman
« Reply #1 on: May 26, 2014, 11:45:06 AM »
Yes remove the fender rails by removing the upper shock mount. The rest should be pretty straight forward. Don't forget the boxed nut behind the fender. It's loose inside a nut cage.
Momz
ABATE, AMA, & MRF rep.
« Reply #2 on: May 26, 2014, 12:06:11 PM »
There are two bolts in the plastic battery box
Be very careful removing the rear plate/signal, the taillight and the terminal/connector between the fender sections.
Take pictures where all the grommets go and be sure you disconnect the battery first.
VOICE OF EXPERIENCE!!!
« Last Edit: May 26, 2014, 12:07:49 PM by Momz » Logged
ALWAYS QUESTION AUTHORITY!
« Reply #3 on: May 26, 2014, 01:54:10 PM »
What Momz said.
You don't actually have to take both chrome rails off.  I only took one side off....and possible didn't need to do that.
There's two bolts that bolt thru the battery box to the front section of the rear fender.  Take those out.  Front section of the rear fender comes out.
Putting it back in and getting those bolts started was a bigger pain for me than taking them out.
It's easier to take the tail light section off of the rear fender section once you've removed the rear fender section.
