March 15, 2026, 06:54:37 AM *
Author Topic: Tourer luggage locks  (Read 1875 times)
sameagle
« on: May 27, 2014, 11:38:14 AM »
It looks like my two bags' locks have seized up.  I have sprayed them with wd 40 rust remover and lubricant with no success.  Any tips on how to free them up would be appreciated or do I need to remove them and put in new lock cylinders?
« Reply #1 on: May 27, 2014, 11:42:34 AM »
I don't know the exact answer to your question, but a while back I got new locks for mine.
I decided it was really hard to take the old locks out, but really easy to remove the guts
from the old locks and put the guts from the new ones in...
« Reply #2 on: May 27, 2014, 11:57:09 AM »
Any good locksmith should be able to pop out the old and install new lock cylinders, and work with your existing key to make single keys that work on all locks on the bike.
Not an expensive deal either.
If you work on it too much first, you may make it worse.
billyboy
st petersburg fl
« Reply #3 on: May 27, 2014, 12:10:31 PM »
I'd try using the key and moving it back and forth. Maybe use some MP master blaster.
That stuff really works good on rusted bolts.
« Reply #4 on: May 27, 2014, 12:20:34 PM »
But the locksmith won't be able to help get this mess out... it is, like, gooed in... kind of like glue, but goo...
waterproofer I guess... I looked at it for a while and decided I didn't want to mess with it...
IamGCW
727 hood
« Reply #5 on: May 27, 2014, 02:08:20 PM »
You sure you're using the correct key?  Just saying.
Gil
Gil
Bert AKA,Valkaholic
Back-N-Black
« Reply #6 on: May 27, 2014, 04:30:11 PM »
PB Blaster Works Very Good .
sameagle
« Reply #7 on: May 28, 2014, 10:37:18 AM »
A lot of sensible tips.  Yes I am using the correct key but always worth the recheck.  I have tried the jiggling with some lubricant.  Will try the PB Blaster.  If not, then locksmith is the way.  Thanks everyone.
FloridaValkRyder
Apopka, Florida
« Reply #8 on: May 28, 2014, 01:54:16 PM »
Powdered graphite has always been very help for me. You can buy it at almost any place that makes keys.
I still miss her.
« Reply #9 on: May 29, 2014, 09:05:37 AM »
Very simple to take apart and put back together just make sure you put the tumbler back in the correct way or the key won't work. If you put it in upside down that is.
