February 08, 2026, 07:30:32 PM *
Author Topic: tach and speedo  (Read 982 times)
dreamchaser
Portland, Oregon
« on: May 30, 2014, 12:08:52 AM »
I can't see my tach or speedo at night safely and  watch the road too.  Is this a common complaint, or is it just me?  Is there a cure for this problem?  I did  a search to no avail.
bikerboy1951
Grand Forks, ND
« Reply #1 on: May 30, 2014, 01:47:03 AM »
Hunt on EBay for a 194 led bulb.  I used a four sided led with one led on top.  It lights up the gauges very nicely.  I know that this type fits, not sure about bigger bulbs.
Brad
« Reply #2 on: May 30, 2014, 03:37:24 AM »
I  installed higher candle power bulbs, but, now, most are using LEDs.
big poppa pump
San Antonio, TX
« Reply #3 on: May 30, 2014, 04:03:01 AM »
Replaced the factory bulbs with LED's from superbrightled and all's well.
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
« Reply #4 on: May 30, 2014, 07:10:36 AM »
It could simply be that some bulbs are burnt out.
quexpress
Montreal, Québec, Canada
« Reply #5 on: May 30, 2014, 08:04:54 AM »
Brad
What do you mean by "four sided led with one led on top"?
A pic would be worth 1000 words.  cooldude
Thanks Brad!
Normand
I still have a full deck.
I just shuffle slower ...
big poppa pump
San Antonio, TX
« Reply #6 on: May 30, 2014, 08:30:11 AM »
https://www.superbrightleds.com/moreinfo/miniature-wedge-base/194-led-bulb-5-led-wide-angle-wedge-base/199/873/
VRCC#35870
VRCCDS#0266
bikerboy1951
Grand Forks, ND
« Reply #7 on: May 30, 2014, 09:17:51 AM »
There is only one bulb in each instrument.
I did a quick check of EBay and came across these.  Item Number 371072631629.  There are many listing both from the US and China.  Find what you like here or go to Superbrightleds.  What ever
you pick will be a tremendous improvement over what you have now.
Brad
dreamchaser
Portland, Oregon
« Reply #8 on: May 30, 2014, 02:16:54 PM »
Thank you all!  I ordered from Superbrightleds & I feel relieved!  I'm looking foreward to my first nite ride being able to know my RPM & how fast I am going.  Grin     Gary
big poppa pump
San Antonio, TX
« Reply #9 on: May 30, 2014, 02:23:34 PM »
Which one did you order? The 'Cool White' gives you the best light disbursement.
VRCC#35870
VRCCDS#0266
dreamchaser
Portland, Oregon
« Reply #10 on: May 30, 2014, 07:25:32 PM »
Cool blue for sharper contrast
big poppa pump
San Antonio, TX
« Reply #11 on: May 30, 2014, 07:42:19 PM »
Uummmmh yeah...thought as much. I did the same thing, before I realized my mistake. The blue led lights up sporadic places in the speedo and tach. Light disbursement is uneven making it very difficult to see certain areas in the night.
VRCC#35870
VRCCDS#0266
chrise2469
Winnipeg Manitoba Canada
« Reply #12 on: May 30, 2014, 11:02:09 PM »
Here's a write up I did with lots of photos.
http://www.valkyrieforum.com/bbs/index.php/topic,34551.0.html
Hope it helps
« Reply #13 on: May 31, 2014, 01:49:42 PM »
You'll want the cool white.  They'll look sorta blue-ish.  The blue is way too blue.
