February 08, 2026, 09:06:20 PM *
Author Topic: Upper Radiator Hose  (Read 797 times)
dan7uk
Louisville, Kentucky
« on: June 03, 2014, 04:32:18 PM »
Just pulled Carb bank out today and notice the upper rad. hose buried in there.  Going to replace it before I put the carbs back in.  Just wondering if the carbs had to be pulled to replace hose or can it be changed with the carbs in place.
« Reply #1 on: June 03, 2014, 04:35:01 PM »
It can be changed without removing the carb bank
N0tac0p
« Reply #2 on: June 04, 2014, 06:23:51 AM »
OK, how about the thermostat, thats in the same location?
« Reply #3 on: June 04, 2014, 06:40:44 AM »
The thermostat can also be serviced without removing the carb bank.
N0tac0p
« Reply #4 on: June 04, 2014, 10:24:39 AM »
but the tank and airbox will have to come off correct?
« Reply #5 on: June 04, 2014, 10:25:28 AM »
No, just the radiator
olddog1946
Moses Lake, Wa
« Reply #6 on: June 04, 2014, 07:37:38 PM »
Only the radiator needs to be moved/pulled. ONE note of caution, pay attention to the clamps and the direction they are in. If you position them correctly they can be re-tightened at a later date with a long extension and socket or long nut driver of the correct size without having to move anything.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
« Reply #7 on: June 05, 2014, 03:03:38 AM »
why changing it? is it leaking?
