July 07, 2025, 06:48:59 PM *
Author Topic: Difference between I/S forks and Standard forks?  (Read 1287 times)
ValkSmile
Cincinnati, OH
« on: August 05, 2009, 11:54:00 AM »
Does anyone know if I can use Standard forks on an I/S? Is there any difference in the two forks?
DFragn
« Reply #1 on: August 05, 2009, 01:15:13 PM »
Different P/N's between the 2 models. My guess would be the springs.
You should be ok to use the Standard tubes if you need to.
May be a little softer tho. You could add an ounce of fluid to each tube to improve the compression feel. That would decrease the amount of air in the tubes for compression.
Or install Progressive springs, which some then decrease the fluid by an oz. or 2. I/S brackets and such will change out.
Many have added heavy fairings to Standards and I don't recall any suspension issues.
Remember: air compresses - fluid does not.
quexpress
Montreal, Québec, Canada
« Reply #2 on: August 06, 2009, 05:28:18 AM »
It shouldn't be a problem.
Note: I went the other way (I/S forks installed on Tourer) but already had Progressive springs. I have not noticed any differences in handling, etc.
I still have a full deck.
I just shuffle slower ...
