February 08, 2026, 10:58:10 PM *
Author Topic: re assemble pumkin and drive shaft  (Read 1107 times)
bill v e
ft. smith, ar
« on: June 11, 2014, 11:02:42 AM »
replacing tire and pulled pumkin and drive shaft - came out as one piece, all connected.  not worried about weep hole this time - all lubed up and trying to re assemble.  having trouble and losing patience trying to get drive shaft end to slide back into ujoint end?  any suggestions or is it just hit or miss after 101 jiggles?
2000 i/s 207k/jun 14
« Reply #1 on: June 11, 2014, 11:09:02 AM »
If the swing arm is DOWN, raise it and the u-joint will slide right into place.
It is best if the swing arm is on the same axis as the frame.
Good Luck.
PS:    When ya get disgusted and pissed off, walk away and have a cold drink, now I never said bubbly stuff, a good COLD glass of iced tea will work just fine, even WATER will work.
Happy Trails.
Peace.
RJ.
bill v e
ft. smith, ar
« Reply #2 on: June 11, 2014, 11:22:01 AM »
ok, thanks.  so I went back and jiggled it in but I think the spring stayed up in the u joint end so I had to push hard and get a nut on to hold it.  wrenched my back in the process but that'll heal.  there is no possible way that tightening down the four nuts (after getting tire back on and axle tight) and letting everything settle in can do any harm, right?
« Reply #3 on: June 11, 2014, 11:39:05 AM »
Doesn't sound right to me. The spring should be held onto the shaft by a washer and circlip. If those weren't on the driveshaft when you removed I would be trying to figure where they went.
« Reply #4 on: June 11, 2014, 12:05:35 PM »
"circlip", don't you mean a Jesus Clip?   Like in Jesus Christ where did that little bastard go.
Then slowly walk over to the box of clips and find a new one.
« Reply #5 on: June 11, 2014, 12:15:37 PM »
Its not right.  When it slips in theres only a fourth of an inch gap between the two flanges.......the nut should go on easy
flcjr
Manhattan,Montana
« Reply #6 on: June 11, 2014, 12:24:47 PM »
ditto
remove the shocks if you haven't already use a tie strap to hold the swing arm level. reassemble and make sure you tighten in correct order. works every time.
bill v e
ft. smith, ar
« Reply #7 on: June 18, 2014, 05:30:49 PM »
ok, thanks.  back should be healed up by next week so i'll take it back out and see where everything is at.  timing should be just about right for my trip starting end of month.  hope for the best!
pancho
Bonanza Arkansas
« Reply #8 on: June 18, 2014, 06:07:05 PM »
If you need a hand Bill, let me know,, I'm in the Fort Smith area,, straighten it out in no time.
quexpress
Montreal, Québec, Canada
« Reply #9 on: June 18, 2014, 06:34:24 PM »
I have found that it is quite easier to accomplish of the bike is in gear. Otherwise it can be painful.
Note: I would accept Pancho's generous offer. This shouldn't be difficult to do and will be much easier after seeing someone else do it.
Good luck!  cooldude
I still have a full deck.
I just shuffle slower ...
« Reply #10 on: June 19, 2014, 07:18:45 AM »
It might be tough to get it into gear with the wheel and drive shaft off and the engine off.  And I wouldn't want to put it in gear with the engine running and the back end of the u-joint not connected.  That being said, I've always managed to get the drive shaft in the u-joint with the transmission in neutral.
quexpress
« Reply #11 on: June 19, 2014, 01:43:58 PM »
Maybe but I do not have a problem doing it that way. I did it again this afternoon (installing new tire).
However re-installing the rubber boot over the universal joint was another story LOL!
