February 08, 2026, 10:57:55 PM *
Author Topic: rusty looking stain around intake  (Read 1005 times)
slider
mulberry arkansas
« on: June 26, 2014, 11:29:38 AM »
found an interesting new item on  one of the intakes on my  girl.She has not complained or run any diffrent.The stain wipes off easily and appears to be rust...I rode thru a pretty good rain for about 30 miles and noticed it this am...could it be time to replace the o rings on the intakes or am I getting worried over nothing..thanks (again)
a proud navy veteran
Grumpy
Tampa, Fl
« Reply #1 on: June 26, 2014, 11:41:08 AM »
Leaking o-rings, the stains are from fuel. Replace them.
BradValk48237
Oak Park, MI
« Reply #2 on: June 26, 2014, 12:24:08 PM »
Ditto.....
Brad
sawdustar
Conway, AR
« Reply #3 on: June 26, 2014, 12:43:25 PM »
Ditto what Grumpy said.  cooldude
Thank You,
Dennis
« Reply #4 on: June 26, 2014, 12:50:04 PM »
Triple ditto cooldude
slider
mulberry arkansas
« Reply #5 on: June 26, 2014, 01:18:57 PM »
thanks for the answers  as usual you guys always bail me out,thanks a million
slider
mulberry arkansas
« Reply #6 on: June 26, 2014, 01:34:44 PM »
would leaking o-rings  affect how it would run,by creating a lean condition??sounds like it would be rough on the engine after a short time..am I corect??
Daniel Meyer
The State of confusion.
« Reply #7 on: June 26, 2014, 02:56:25 PM »
Not really. They have to be REALLY bad before it's significant. The stain is after you turn her off...fuel vapor condenses in the intake tube and the now liquid runs down..then wicks out the o-ring seal.
CUAgain,
Daniel Meyer
Farther
Quimper Peninsula, WA
« Reply #8 on: June 26, 2014, 04:24:55 PM »
That started on mine after using a can of B12 Chemtool but has now stopped.  I would change the O rings but every time I go to the barn to do maintenance on the Valkyrie I go for a ride instead.
~Farther
blackvalkyrie
California
« Reply #9 on: June 26, 2014, 04:30:44 PM »
everyone's right..it's o ring's..really a simple task..just did mine and changed the plugs..the threads on the plugs were wet not the tips, all in all pretty  easy job
« Reply #10 on: June 26, 2014, 06:07:06 PM »
Can't disagree with any of the above.  cooldude You might also want to check the torque (7 ft-lb) on the screws holding the intakes in place, particularly where you say the stain. Another possibility to explain the stain(s) is that a fuel rail Oring is leaking.? The latter should yield a smell of gas.
FWIW   Roll Eyes
My rides:
« Reply #11 on: June 26, 2014, 07:28:48 PM »
Check the thread "Leak: Interstate 99"
« Last Edit: June 26, 2014, 07:30:43 PM by sandy » Logged
« Reply #12 on: June 27, 2014, 04:56:23 AM »
http://www.valkyrieforum.com/bbs/index.php/topic,69409.0.html
My rides:
