February 09, 2026, 12:57:35 AM *
Author Topic: moly paste-- hard to find here  (Read 1254 times)
slider
mulberry arkansas
« on: July 03, 2014, 07:19:45 AM »
having hard time around here locating the moly paste for  maintance   can find  at honda  dealer but heard the honda wasnt very highly recommended.Cant find guard dog at all.Any suggestions  at all  none of the auto parts stores have it  I did find some diffrent brand at a yamaha dealer ...and its yamaha brand  anyone use it?one auto store clerk   told me that he had never heard of such a thing and didnt think there was such a thing in the first place, he called himself a parts tech so he must know what he is talking about  --imagine that  .thanks guys.
a proud navy veteran
« Reply #1 on: July 03, 2014, 07:25:49 AM »
I think Honda moly60 has a bad rap, I use it, but if you want to avoid it,
you can get a tub of 60% moly paste at Grangers if you have one near by.
97Valk_CT_Euless
Euless Tx
« Reply #2 on: July 03, 2014, 08:24:26 AM »
I use Honda.  It's pricey, but haven't had a problem.  zero wear on the new splines a couple years ago.  Just did second tire change and zero visible wear.  I also change the o-rings every time tho.
« Reply #3 on: July 03, 2014, 09:51:59 AM »
Engine assembly grease is high moly, any auto parts store.  Hoser
« Reply #4 on: July 03, 2014, 09:59:25 AM »
The Honda Moly 60 paste works for me.
« Reply #5 on: July 03, 2014, 10:41:12 AM »
That would be great. I searched around, trying to find some info...
http://www.belray.com/sir_tech?page=1
A lot of assembly lubes say "Moly", but it is hard to find out how much.
The belray apparently has 40% moly.
A lot of people put their final drives together with no-moly grease,
and have perfect success after 100K...
« Reply #6 on: July 03, 2014, 11:05:58 AM »
Never used moly paste in 143K and have zero wear. Bel Ray waterproof grease. I use Valvoline Durablend (3% moly) on the drive shaft and pinion cup.
« Reply #7 on: July 03, 2014, 11:38:01 AM »
I use tht on everything. Havent used moly paste in yrs.
slider
mulberry arkansas
« Reply #8 on: July 03, 2014, 11:43:20 AM »
finally found the moly  at local yamaha dealer,am mixing with the belray tacky red water proof.thanks everybody again
« Reply #9 on: July 03, 2014, 11:46:16 AM »
I have used nothing but Del-Ray WATERPROOF wheel bearing grease for 243K+ miles on MGM, NO problems.
« Reply #10 on: July 03, 2014, 06:14:21 PM »
http://www.tsmoly.com/catalog/advanced_search_result.php?search_in_description=1&keywords=ts70
70% moly
Bigwolf
Cookeville, TN
« Reply #11 on: July 04, 2014, 12:04:14 PM »
I ordered from here: http://www.guarddogmoly.com/index.shtml
Bigwolf
67blkbrd
« Reply #12 on: July 05, 2014, 12:50:27 PM »
I have a tube of Swepco molly that I just used when I replaced the rear tire. If you haven't had any luck tracking some down I can talk to our vendor on Monday and see if there is one in your area.
« Reply #13 on: July 05, 2014, 09:38:33 PM »
Used Belray when working on boats and use it now, good stuff.  cooldude
Brian
Monroe, NC
« Reply #14 on: July 06, 2014, 04:53:56 AM »
Guard Dog is a supporter of this site. I believe this is mail or on-line ordering only. I have been using their product. Grainger's sells the Loctite Moly paste, I bought this product off Amazon for the same price that Grainger's wanted and it was shipped to the house. I used the Belray product years ago on my Yamaha Virago with no problems. Not sure why I have not continued to use it? I find the GD stuff is still spun out on the hub even though I replace the O-rings every spring with the rear end maintenance. The splines still seem to have lube on them. No matter what you use the main thing is you do it. A fellow valk rider in our club runs out west every summer. His rear end maintenance was always done by the dealer at tire time. He averages 20,000 miles on E3's. He lost his splines at about 100,000 miles. My guess is the Honda dealer used the Honda stuff and it did not hold up the to high temperatures of the desert road temps. He now has his splines lubed more often.
