February 09, 2026, 12:57:34 AM
float bowl vacuum test
Topic: float bowl vacuum test (Read 751 times)
Otus
Scott
Taylor Mi.
July 03, 2014, 12:43:17 PM »
Getting ready to change my slow jets and I have one float bowl gasket leaking. Since I am opening up all the carbs I am changing all the 13 year old float bowl gaskets. I searched it and attic rat said it was a test to See if the gaskets are bad. So if I'm changing them all anyway is this a step I can skip? Also the gasket set I got from red eye came with a paper which said if you wanted to glue them on like honda to get a 3m adhesive. Is this necessary or will a little grease be sufficient to hold them in the groove when I set the bowl back on?
http://www.visitedstatesmap.com/image/KYMIMNNCOHTNWIxlg.jpg
Attic Rat
VRCC # 1962
Tulsa, OK
Re: float bowl vacuum test
July 03, 2014, 03:30:23 PM »
Scott I always glue them in so they don't move just like the factory does. I also always vacuum test them when I am thru to make sure that they don't leak. I just follow what the book says and it has always worked out for me.
Otus
Scott
Taylor Mi.
July 03, 2014, 03:33:51 PM »
Thanks again attic rat.
