February 09, 2026, 12:57:51 AM *
Author Topic: Dumb Question?? Maybe  (Read 1005 times)
flcjr
Manhattan,Montana
« on: July 07, 2014, 12:46:33 PM »
I am gonna help a friend do the rear end spline and shaft service. His is a 97 standard. Honda list three valks that year,are all the orings and drive shaft seals and thrust washer the same?? He can't be reached to find out if it is a 1500A,1500C,or 1500CT.
I think the only difference is the shaft on a 97??
« Reply #1 on: July 07, 2014, 12:59:37 PM »
all parts are the same
nogrey
Nampa, Idaho
« Reply #2 on: July 07, 2014, 01:23:17 PM »
Yep, all parts are interchangeable so you should be good. Not much needed for a service anyway. The right grease, the right gear oil, and the O-ring set and you're good to go. Have fun!
Careful taking the rear tire off. My brother just dumped his interstate off a lift because he removed the rear tire with the front tire off the ground. I wasn't there but he said it toppled forward.
flcjr
Manhattan,Montana
« Reply #3 on: July 07, 2014, 01:26:08 PM »
Thanx I thought I was correct on the seals but where fifty miles from a dealer who doesn't stock any parts so have to order them. Just wanted to be sure.
flcjr
Manhattan,Montana
« Reply #4 on: July 07, 2014, 01:27:16 PM »
Ouch that sucks. I always tie the bike down to the lift and never have a problem.
« Reply #5 on: July 07, 2014, 05:57:54 PM »
Just an FYI.
There where only 2 Valks, the C and CT (Standard and Tourer) until the Interstate CF came out in 99-01.
I believe the A is for a Goldwing Aspencade. I've seen the A and I given for GW. Some parts are the same.
saddlesore
« Reply #6 on: July 07, 2014, 07:56:34 PM »
I tie up to the jack but I also put some jack stands under the crash bars. Better safe than sorry. cooldude
DARE TO BE DIFFERENT
indybobm
Franklin, Indiana VRCC # 5258
« Reply #7 on: July 08, 2014, 07:00:51 AM »
Do not forget to put the Thrust Washer between the Wheel and the Drive Flange. Easy to miss and VERY important.
So many roads, so little time
VRCC # 5258
