February 09, 2026, 12:57:31 AM *
Author Topic: Interstate with annoying rattling noice  (Read 914 times)
Dag
Country Rep. Norway
« on: July 07, 2014, 02:01:51 PM »
It`s coming from the alternator side of the engine. Maybe behind the alternator.
This happens only when the engine is cold, and dissapears after less than one minute.
I`m not 100% sure, but I dont think it comes from the clutch.
Could it be the chain to the oil pump?
Any ideas?
Thanks  cooldude
F6Dave
« Reply #1 on: July 07, 2014, 02:51:56 PM »
My Interstate has rattled when cold since I bought it with 6,800 miles.  The noise disappears quickly as the engine warms.  I've owned the bike for 9 years, and it now has over 93,000 miles.  It used to worry me but now I ignore it.
BonS
Blue Springs, MO
« Reply #2 on: July 07, 2014, 03:18:00 PM »
I've had the heat shield, located beneath the foot pegs, rattle. I don't remember much but I tightened things up and may have pulled the heat shield out a little bit (bent) and that fixed it.
Grumpy
Tampa, Fl
« Reply #3 on: July 07, 2014, 07:09:08 PM »
I doubt it is the oil pump chain, I had the guard on the chain come loose a couple years ago, noise got worse as the bike warmed up. Fix was the bolts on the guard had come loose. Must have been put together on a Friday at 10 min before quitting time.  crazy2
Dag
Country Rep. Norway
« Reply #4 on: July 08, 2014, 02:07:26 PM »
Problem solved. It was the alternator.
« Reply #5 on: July 08, 2014, 07:32:06 PM »
Glad to hear you found it.
But what part of the alt? the whole thing, so tightened the mounting bolts, or ??
