April 29, 2026, 07:04:09 AM *
Author Topic: Powerlet outlet placement ... ?  (Read 6706 times)
Bagger
VRCC #102
CT-USA
« on: July 07, 2014, 04:07:54 PM »
I said I would not mod this bike.  Yeah, that lasted as long as it took for the ink to dry on the check.   ???
I have several things coming ... mostly small stuff ... Kuryakyn grips in black, risers that I prolly can't use, brake pedal extension, short range levers (I'll do some Ironbraid when they fit), Utopia backrest, yada, yada.
But, now ... I'm wondering about other stuff I typically add to my bikes.  One is Powerlet outlets to charge the batter, run a radar detector, charge a phone, power a GPS, heated vest, etc.
But, I'm looking for some ideas / suggestions.  Where would you mount a Powerlet outlet ... maybe 2? ... on the bike?
CajunRider
Broussard, LA
« Reply #1 on: July 07, 2014, 07:54:39 PM »
One of these can go in the "glove box" just under the left handlebar (I think the adapter plug will fit the supplied plug directly under the glove box):
http://wingstuff.com/products/34624-2-port-usb-auxiliary-socket-for-gl1800?from_search=1
You can also get a typical cigarette lighter outlet from any auto parts store (the weather resistant ones are best) and wire it to the battery through a (fused) relay controlled by the accessory port of the relay box so that it turns on/off with the key.
Sent from my Apple IIe
Dave Ritsema
South Bend IN
« Reply #2 on: July 08, 2014, 03:40:37 AM »
Yeah, we all start out with good intentions then we get caught up in things don't we?  Grin
I think I might go with this powerlet option on your bike, very flexible mouning options, pretty much any existing bolt will do and it comes in black.
http://www.powerlet.com/product/type2-rearset-kit/161
VRCC 2879
Lake City Honda Warsaw IN
Bagger
VRCC #102
CT-USA
« Reply #3 on: July 08, 2014, 07:06:29 AM »
Thanx, Dave .... yeah, there are many options.  I think I want something closer to the handle bars for the GPS/radar detector hook ups.  I've had them 'hard wired' on a couple bikes, but like the idea of being able to just unplug if wet weather comes in.
The bolt mount may be good for heated vest / clothing, or battery tender.
Tooooo many choices!
bassman
« Reply #4 on: July 08, 2014, 07:23:38 AM »
M'be something like this for the handlebar?
http://cycleplicity.com/products/67471-kuryakyn_1423_universal_handlebar_electrical_power_point.aspx?utm_source=google&utm_medium=cpc&utm_content=67471NOFITMENT&utm_campaign=GSNOFITMENT&adtype=pla&kw=&utm_term=&adpos=1o1&network=g&gclid=CKTx0In0tb8CFdIWMgodD3wAzg
Bagger
VRCC #102
CT-USA
« Reply #5 on: July 08, 2014, 07:36:05 AM »
Yeah, maybe .... something in black, tho.  I think Powerlet has a plug with a ball mount attached so a GPS / Escort can be attached.
I may get a couple different hook ups.  Heck, I should check some of the boxes in the garage from other bikes I've had 'stuff' on and now are in storage.
