February 09, 2026, 12:57:46 AM *
Author Topic: desmog vac line #1  (Read 788 times)
tbonetbone5
« on: July 07, 2014, 10:12:37 PM »
hi,new here ,  i did a desmog on my valk,and for the life of me cant see where the #1 right side   vac hose goes or if it  gets blocked ,i looked up on the internet but nothing ,,close but nothing abou tthe # 1  vac ,my eyes aint great but didnt see anything ,can anyone tell me the order of the vac hose s go after desmoging  . ty T.
« Last Edit: July 08, 2014, 01:21:33 AM by tbonetbone5 » Logged
« Reply #1 on: July 08, 2014, 03:29:32 AM »
Carb #1 should have a boost cap on the intake nipple desmogged or not.  The only hose you should have from the intakes are on #6 to the fuel petcock, if your petcock is stock.
« Last Edit: July 08, 2014, 03:31:38 AM by Hook#3287 » Logged
tbonetbone5
« Reply #2 on: July 08, 2014, 07:14:39 AM »
so every intake is closed off except 6. t. ty
nogrey
Nampa, Idaho
« Reply #3 on: July 08, 2014, 07:23:56 AM »
Yes. To clarify, when you removed all of the "smog" equipment, you were still left with a series of rubber hoses. 6 of them go to the bottom of the carburetors. Each carb has an outlet on the float bowl. These are not vacuum lines, but drain lines for the carbs should you wish to drain them. I remove these as I never use them and it cleans up the engine considerably.
If you used a desmog kit, it should have come with 5 vacuum caps. These go over the ports on the down tubes (shiny chrome tubes from carbs to engine block). Their should be a cap on #1, #3, #5 on the right side and #2 and #4 on the left side. Hint: each spark plug wire is numbered.
#6 should have a vacuum hose that goes to the petcock. That is the only vacuum hose you should have.
Don't forget to block the unused hole in the air box.
Also, if you want to go "vacuum hose-less" altogether, you can replace your petcock with a pingle manual petcock.
Hope this helps and welcome to the board.
tbonetbone5
« Reply #4 on: July 08, 2014, 08:28:52 AM »
thank you guys , i did want you guys said and it worked , i still have to stock p .c. but i never knew about the pingle petcock ,as far as the markings on my spark plugs , my valk is so old the markings are gone but able to know whats where ,thank you guys again.T...........
