March 11, 2026, 07:40:04 AM *
Author Topic: For the 'puter techno types . . .  (Read 1375 times)
sheets
Jct Rte 299 & 96, Calif.
« on: August 07, 2009, 05:23:28 PM »
Finished up my powerpoint (Valk) show with music synced to pix.  Burned it on a CD.  Music plays from the CD, all is well.  When I save it to the 'puter and play it, the pix advance as planned, but no flipp'n audio.  Where's the music???  I don't get it.  CD version works fine.  C: drive version advances, but like a silent movie.  What's up with that??   Undecided   sheets
DavRed
Buckeye AZ
Phoenix AZ
« Reply #1 on: August 07, 2009, 05:57:22 PM »
Powerpoint has pointers to the music files. So when creating a power point it is best to place the music files and pics all in the same folder and point to them. Also you can save it as a powerpoint show. Then the audio is imbeded on it. However that file can not be edited. I think I am correct about this. If not I am sure someone elce will chime in shortly....
sheets
« Reply #2 on: August 07, 2009, 06:34:42 PM »
. . . but that doesn't mean anything, cuz I know just enough to be dangerous.  Where I created the show, at my "other" location, I have the pix in one folder and music in another.  I created the PPS by selecting pix from one folder and selecting music from the other folder.  In PPS I timed the frames to sync the music.  It works fine at "that" location.  I copied to a CD and brought it home.  The CD version at "this" PC works fine.  The version saved and or copied to the C: drive at "this" PC runs like a silent movie.  Select the drive with the CD and it works fine.  Select the file saved to the C: drive and its a silent movie.  This stuff drives me nuts!!  I don't know how you IT guys do it.  Give me a steering wheel and 13 speeds, or a machine with 14 levers, and I can make it tap dance.  Give me the stink'n 'puter thingie and I'm fine with throwing it out the window.  Thanks for the advice . . . sheets
BonS
Blue Springs, MO
« Reply #3 on: August 07, 2009, 06:55:29 PM »
I don't know what format of video/audio you put onto your CD but more than likely you're missing the "audio codec" needed to play back the audio on the PC that is silent. What type of audio/video files are on the CD?
sheets
« Reply #4 on: August 07, 2009, 07:11:46 PM »
Beats the hell out of me.  I don't speak that language. But Thank You for responding.
DavRed
Buckeye AZ
Phoenix AZ
« Reply #5 on: August 07, 2009, 07:59:34 PM »
Just copy all the files from the original pc and put them in a folder. Then add that folder to the cd with the Power point show. All should be good.
gota love Bill Gates,,,, I know
Sorry reread your post. and what you need to do is copy all the contents from the CD to a folder on your PC then run it from there. That should do it.
 Hope I helped
« Last Edit: August 07, 2009, 08:03:17 PM by DavRed » Logged
sheets
« Reply #6 on: August 07, 2009, 09:05:44 PM »
That worked!!!!!  I don't know what difference that makes, and don't even try to esplayne it to me.  I've got my PPS on the hard drive and I'm happy.  Twenty-four Valk travel pix to to the tune of Roll Me Away . . . .  My first attempt at PPS.  I'm impressed, if I do say so myself.   cooldude  Cool
JDW365
North Newton, Kansas
« Reply #7 on: August 07, 2009, 09:34:14 PM »
So when do we get to see this creation or is this just a tease!!  Smiley
BonS
Blue Springs, MO
« Reply #8 on: August 08, 2009, 04:18:38 AM »
Glad you got it working!
DavRed
Buckeye AZ
Phoenix AZ
« Reply #9 on: August 08, 2009, 05:26:57 AM »
Good deal, now post it for our enjoyment... cooldude
sheets
« Reply #10 on: August 08, 2009, 07:44:26 AM »
I have a dial-up connection so this type of stuff takes forever to pump through the pipeline.
Do you post it like a picture?  It's 27 slides w/music = 10.3 MB (whatever that is).
Thanks for the assist.  sheets
