November 26, 2025, 03:50:24 AM *
Author Topic: thrust washer?  (Read 883 times)
« on: July 26, 2014, 01:58:46 PM »
I have my Interstate torn down to the frame Shocked
so I am going through the rear end and all splines and such look great but there was no Thrust Washer between the final drive gear flange and the bearing hub where the shop manual says there should be one? where could have gone. tech leave it out at a tire change? or what?
« Reply #1 on: July 26, 2014, 02:11:52 PM »
You sure it's not stuck in the wheel with grease? It not you got lucky no wear cooldude
« Reply #2 on: July 26, 2014, 02:12:14 PM »
If everything looks OK, maybe it is really there... have you cleaned up the flange
and the wheel?
-Mike "it is important..."
« Reply #3 on: July 26, 2014, 02:13:24 PM »
will look again but cleaned everything up pretty good.
« Reply #4 on: July 26, 2014, 02:25:22 PM »
found it uglystupid2 it must have fallen out when I pulled the drive flange and rolled across the floor and it being Nylon , no noise when they hit concrete 2funny
heavyd
« Reply #5 on: July 27, 2014, 03:51:08 AM »
You are lucky, I have seen what happens when the PO doesn't put the thrust washer back in.
http://www.valkyrieforum.com/bbs/index.php/topic,42992.msg414547.html#msg414547
« Reply #6 on: July 27, 2014, 06:32:04 AM »
Do you grease up the washer and hub? Mine always sticks to the wheel or hub. Never had one fall off.
« Reply #7 on: July 27, 2014, 07:50:02 AM »
First time I have personally had it off,and no there was no grease on it  but plenty on everything else plonks and such they look almost new.
« Reply #8 on: July 27, 2014, 06:25:09 PM »
When you put it back I would lightly grease all areas of the hub and washer, the hub studs that go down in the dampeners, and of course new orings and grease or paste on the splines cooldude
