January 29, 2026, 08:30:29 AM
Low beam out on headlight
Topic: Low beam out on headlight (Read 1676 times)
Farther
Quimper Peninsula, WA
August 09, 2009, 08:05:53 PM »
I happened to notice today that I have no low beam. High bean still works. I am hoping a bulb change will fix it. Can someone stear me to a headlight bulb replacement diagram and recommend a bulb that will not melt anything and be good for my old eyes?
~Farther
vanagon40
Greenwood, IN
Re: Low beam out on headlight
August 09, 2009, 08:45:41 PM »
Since you refer to "a" bulb, I assume this is a Standard/Tourer. A standard H4 at any local parts store for about $5.00 is the quick, easy fix. Lots of other folks will chime in with better but more expensive options.
August 10, 2009, 08:19:26 AM »
Best to stay in the same wattage range.
Too high a wattage can have disastrous effects on you wiring and other related electrical components.
