February 09, 2026, 08:57:33 AM *
Author Topic: Redeye o-ring question, which is the probmatic o-ring?  (Read 1259 times)
lljjmm
« on: August 13, 2014, 07:40:45 AM »
There was some previous talk about an issue with a Redeye o-ring (the red one) that made mating  of the rear wheel  and rear differential difficult - Which o-ring was creating the problem?
I am going to use the Redeye o-rings and would rather not have the problem and use the oem o-ring in the probmatic ones  place.  Thanks in advance, (was having issues in the archives)
« Reply #1 on: August 13, 2014, 07:58:02 AM »
Redeye makes good stuff, but I've always used these. They're real good
and the price is right...
http://www.carolinabikeandtrike.com/ORings.htm
specialdose
Jonesboro, Ga
« Reply #2 on: August 13, 2014, 10:15:36 AM »
          I use the Redeye, no problems.
« Reply #3 on: August 13, 2014, 06:12:53 PM »
I'm sure if there is an issue, Rich at Redeye will tell you.
My rides:
DenverDave
Out past Mars ain't no speed limit -Mojo
« Reply #4 on: August 13, 2014, 08:37:07 PM »
Just hours ago I finished the rear end maintenance on my bike, first time with the Red Eye o rings.
My first time was with the Honda rings.
Just follow the enclosed instructions.
A few good whacks on the final drive and everything slipped into place.
The "hidden" 3rd o ring and the big  o ring on the five pin spline are slightly thicker than the Honda OEM o rings, and with the material the red eye o rings are made from, makes it a little harder to slip the wheel assembly back onto the final drive.
I also replaced the dampers in the rear wheel, what a difference.  Got rid of the slack in the drive line. I guess the 15 year old dampers were just a little loose.   Wink
Looking forward to my next ride  cooldude
Dave
1999 interstate green/silver
Denver, Colorado
VRCC#32819
VRCCDS#0238
