January 29, 2026, 08:30:31 AM *
Author Topic: Three O rings in rearend?  (Read 2095 times)
Mr.BubblesVRCCDS0008
« on: August 10, 2009, 07:57:55 AM »
Ok I went and did it. I broke the number 3 oring in the rearend. It's Monday and all bike shops are closed. Does anyone know the size numbers  so I can get one or all of them at a hareware store. We've got all types of them here at work but if I have the number it would be much easier.
« Reply #1 on: August 10, 2009, 08:06:35 AM »
Here's a help if you can identify which 'o' ring you refer to.
http://fiche.ronayers.com/Index.cfm/Module/Main/TypeID/26/Type/Motorcycle/MakeID/1/Make/Honda/YearID/41/Year/2000/ModelID/7142/Model/GL1500CT/GroupID/309312/Group/FINAL_DRIVEN_GEAR
The information is right there in the description of the part.
« Reply #2 on: August 10, 2009, 08:29:04 AM »
OK it's the 39.5 X2.4  oring. Is there a chart or something to get over to U.S. sizes. I know it is a 100 series that is the dia. of rubber of the ring.
« Reply #3 on: August 10, 2009, 10:16:38 AM »
Well, that's metric and any good supply house should have them listed that way also.  A cross over is easy.  The 2.4 is the diameter of the 'o'ring material and the 39.5 is the base circle of the 'o'ring.  I don't know series and wouldn't even try to hazard a guess.
Searching on google ought to come up with a lot of help.
alan
« Reply #4 on: August 10, 2009, 11:40:25 AM »
When I saw Mr Bubbles had three O-rings in his rear end I thought I'd logged onto Facebook by mistake.    I'm just sayin'.......don't wanna start a riot, but it's rainin' here today......
Sharkey
GOT CURVES??
VRCCDS0184
« Reply #5 on: August 10, 2009, 02:36:17 PM »
For a little money you can get them here from Matt. http://www.carolinabikeandtrike.com/ORings.htm
Its $13 for 5 sets of all three rings. He ships quickly
Steve K (IA)
Cedar Rapids, Iowa
« Reply #6 on: August 10, 2009, 06:40:02 PM »
Now that's funny! 2funny
States I Have Ridden In
Madmike
Campbell River BC, Canada
« Reply #7 on: August 10, 2009, 08:41:51 PM »
http://www.oringswest.com/
A 129 may fit in a pinch..........
35.4 MM is ID of o'ring.... 25.4 MM = 1 inch
35.4MM = 1.555"
1 MM = .040" rough and dirty
2.4mm  = .096"
100 series is close.......
129 spec. is on chart in link.....
there......... Canada switching to metric 30 years ago finally paid off......... if I did the math correctly in my head.......
« Last Edit: August 10, 2009, 08:56:01 PM by Madmike » Logged
« Reply #8 on: August 11, 2009, 08:53:26 AM »
I din't find one yesterday but, I remembered I had a spare final drive in the cabinet at home so I robbed the ring from that one and I'm back on the road today. I'll order some shortly.
