February 09, 2026, 08:57:32 AM *
Author Topic: Twinmax synchronizer instruction  (Read 2060 times)
Peter55
Fairfax VA
« on: August 16, 2014, 02:42:06 PM »
Hello all,
I haven't really ridden my I/S for sometime and I even forgot how to sync the carbs. I have a Twinmax synchronizer but I lost the instructions on how to do it on the Valk. I know there are some instruction on the Tech Board but for a different sync instrument. If you have a PDF file save somewhere I would appreciate if you can share it. TIA
« Reply #1 on: August 16, 2014, 04:35:42 PM »
Sync gauges are sync gauges. Just attach vacuum lines to the vacuum ports and adjust each carburetor to match #3 [ which is the non-adjustable one].
« Reply #2 on: August 16, 2014, 06:12:36 PM »
My question is why haven't you been riding her? We all know Phat gurls love to be ridden angel
« Reply #3 on: August 16, 2014, 07:20:43 PM »
Holy Crap!  Do I need to stop riding? I have owned my girl for 12 years and put 135K miles on her and never sync'd the carbs............am I doing it all wrong?
« Reply #4 on: August 17, 2014, 05:42:06 AM »
Oh My Gosh, your bike is about to self-destruct !  No sync ? Isn't that against some law ?
I'd be willing to bet that it'll still stand up a nickel.
Peter55
Fairfax VA
« Reply #5 on: August 17, 2014, 05:50:08 AM »
[Holy Crap!  Do I need to stop riding? I have owned my girl for 12 years and put 135K miles on her and never sync'd the carbs............am I doing it all wrong?
[/quote]
No, but if feels much smoother with the carbs synchronized. And you can certainly hear it on idle.
My I/S has just 30K and although I don't ride it much I like keeping it in top shape. Nice to know I could get up to 130K. ;-)
« Reply #6 on: August 17, 2014, 08:14:40 AM »
Generally, if the carbs have been sync'd once in the past, you shouldn't have to touch them again unless they've been worked on.
« Reply #7 on: August 17, 2014, 08:36:05 AM »
You would win that bet Patrick, I do the nickel trick all the time.  Sometimes at the request of people that know about it and want their friends to see it, Always works
Thunderbolt
Worthington Springs FL.
« Reply #8 on: August 17, 2014, 09:42:01 AM »
Turn the Twinmax on and zero the meter.  Turn the sensitivity all the way up.  Put the A vacuum line on #3.  Put the B vacuum line on #4.  Crank the bike and watch the needle, if it hovers to the right of zero turn the sync screw on #4 to the left until it hovers over zero.  If it hovers to the left side of zero turn the sync screw on #4 to the right until it hovers over zero.  If you have not desmogged your bike put a golf tee or similar item into the vacuum line that you removed from #3 and move on to the next cylinder.  I usually just do # 2 and #6 while on that side and then go back to the right side and do #1 and then #5.  Take the gold tee out and put all the lines back on.
