February 09, 2026, 06:56:30 AM *
Author Topic: speedo / tach size  (Read 769 times)
Fathertime
Washington County, New York
« on: August 20, 2014, 07:45:46 PM »
Can anyone confirm or deny that the bezel size on the speedo and tach remain constant for the standard through all years of production?
« Reply #1 on: August 20, 2014, 08:20:26 PM »
No. But have you looked at the parts fische to see if the Tach/Speedo stayed the same in all year models, and you will have your answer if they did.
wastingtime
« Reply #2 on: August 21, 2014, 07:40:08 AM »
This is the "other half"  of Father Time here--
Don't have a fiche for these---have a crabby customer claiming that his--and only his!!!!---2003 speedo and tach don't fit an accessory part he bought.  OR at least ONE of the items doesn't fit--they are identical.
So--how do I find such a fiche?
Is this something Honda could answer????
Thanks!!!!
wastingtime
« Reply #3 on: August 21, 2014, 08:16:10 AM »
Ooooookaaaayyyyy--
.hondapartshouse.com/oemparts/
The speedo and tach for the 2000 Valkyrie cruiser and the 2003 Valk cruiser ( the only ones I am concerned with this instant) are the SAME according to the easily searchable micro fiche at the above
Much easier to use than the ron ayers site (or so I found)
IF I KNOW the part fits our 2000 then I am pretty sure it will fit the SAME model speedo/tach on the 2003.
« Reply #4 on: August 21, 2014, 09:09:46 AM »
The only difference I've seen is the colour of the backlighting.  Don't know which years are what except my 2000 Tourer has red lights.
« Reply #5 on: August 21, 2014, 04:40:18 PM »
Yes. Which is why I said if they match, then they do.
If they don't match, then it might just be like you said, a difference in the color. Doesn't mean for most purposes that they aren't the same. Fit would be.
« Last Edit: August 21, 2014, 04:49:47 PM by gordonv » Logged
