February 09, 2026, 06:56:33 AM
final drive..
Topic: final drive.. (Read 879 times)
Hox
final drive..
August 20, 2014, 07:56:30 PM »
Inspected final drive..still OK but starting to get some howl from worne splines, (10% +- gone) cush drive rubbers etc....any thoughts short of replacing it...
the. Rick
Re: final drive..
August 21, 2014, 03:19:48 AM »
If either spline set is only 10% worn, I just I would just clean them up, degrease them and go riding. If the dampers are a little sloppy, I'd replace them.
Re: final drive..
August 21, 2014, 04:42:31 AM »
Quote from: Patrick on August 21, 2014, 03:19:48 AM
Don't you mean re-grease?
Re: final drive..
August 21, 2014, 07:38:51 AM »
Quote from: Bighead on August 21, 2014, 04:42:31 AM
Ooopps, Yep, you're right, thanks. I guess I need to get more better at proof-reading.
Re: final drive..
August 21, 2014, 09:12:52 AM »
Splines won't howl even when worn. Tires, bearings, and gears can howl but not splines.
Hox
Re: final drive..
August 21, 2014, 08:17:50 PM »
Thanks all.... thought about the tire issue... was replaced while they were doing inspection and howling seems to have stopped... will take care of splines as suggested. Hox
