January 29, 2026, 08:29:59 AM *
Author Topic: symptoms of worn out race?  (Read 1637 times)
Fajack
« on: August 10, 2009, 04:51:29 PM »
Any experience with a worn out race in the steering head?   I'm having a little front wheel wiggle at 35-40 mph and  my tire was recently balanced  (a new Avon Venom)
Jack
Michvalk
Remus, Mi
« Reply #1 on: August 10, 2009, 05:29:36 PM »
I have read, posted on this board, that steering head bearings can go bad. yours could be bad, or too loose, or it could be the tire. I have a new cobra that does the same thing, and I know that the steering head bearings are loose. The last tire I had on did the same thing.(Dunlop E3) At 40MPH or so it goes away and rolls smooth. There is a procedure for adjusting the steering head. That stuff is available in the service manual and on this site in the tech board. just do a search and read up to your hearts content
« Reply #2 on: August 10, 2009, 05:36:36 PM »
Easiest is to take the front wheel off and wiggle/move the bars. The less weight on the front end is better. I did mine last summer cause I thought it was bad. This spring I had the wheel off and noticed the bars are loose. Rechecked the torque and all is good. Just be sure to recheck the torque and a few hundred miles.
T.P.
Apple Valley, Minnesota.
« Reply #3 on: August 10, 2009, 06:24:55 PM »
Ebony Red and I both had tire wobble going on,  YEP fixed the problem with Dyna Beads.  cooldude
