July 08, 2025, 09:35:32 AM
Found a way to drop my gearing....
Pages:
Topic: Found a way to drop my gearing.... (Read 6817 times)
Hellcat
Arlington, VA
Re: Found a way to drop my gearing....
Reply #40 on:
August 18, 2009, 12:35:28 PM »
Quote from: CA ExhaustCoatings on August 18, 2009, 07:15:13 AM
Quote from: theopowers on August 17, 2009, 07:03:06 PM
Quote from: CA ExhaustCoatings on August 12, 2009, 04:36:26 PM
Air filter setup stock filter with metal screen removed. Intake air tubes modified to be straight. Airbox lid modified, stock opening sealed, two holes 1 3/4' ea drilled into front of lid. requires re-jetting and tunning.
Ignition mods modified stock TW for 6 degrees, with dyna, curve 7, +10 degrees at hwy speeds. -10 degrees curve is +/-1 degree compared to stock I/S ICM. stock coils. did have CBR1100xx coils, but they kept burning out the dyna, although spec wise they shouldn't have.
Any write-ups out there about the air filter mod? And can you run 87 gas with your ignition mods?
87 octane all of the time no problems. just pop the metal screen off to increase airflow. And the filter last much longer than the 12k honda says.
any idea how the k and n compares to that mod?
Reply #41 on:
August 18, 2009, 01:12:32 PM »
[/quote]
K&n lets in too much dirt, its a race track item. oil anaylsis will show how much dirt it allows into an engine.
The oem filter is a great filter, it provides plenty of airflow due to its large surface area and airbox, my bike dyno'd 100 HP. This is the marketing trick K&N used yrs ago. they found a car with an undersized aircleaner/filter which restricted top end power. Put in a k&n or no airfilter, more airflow, more power. So the marketing result was a K&n filter in any application increases HP, which is just not so. this is good to read
http://www.rc51.org/airfilt.htm
some links
http://www.ibmwr.org/otech/airfilter.html
http://www.lubespecialist.com/airfilt.htm
http://www.fordmuscle.com/archives/2000/01/airfilters/index.shtml
http://www.safari4x4.com.au/80scool/tech/filters.html
http://www.donaldson.com/en/index.html
http://www.baldwinfilter.com/
http://www.gadgetonline.com/airinduction.htm
http://vettenet.org/knfilter.html
http://www.seansa4page.com/resource/airfilter.html
http://www.seansa4page.com/frames/autotechmain.html
http://www.uti.com/~hoser/K%26N4.htm
http://uaf.com/
Good tech
http://www.bmwe34.net/E34main/Upgrade/Air_filter.htm
http://www.ramair
filters.com/frames.html Click on filter facts
http://www.filtnews.com/
http://theoildrop.server101.com/cgi/ultimatebb.cgi
Great oil and Air filter forums
http://www.dirtcheapracing.com/tech/airfilter/
http://www.bolhuijo.com/airflowtest/index.html
http://www.mcagraphix.com/filter/test.htm
http://www.cummins.com/na/pages/en/customerassistance/faq/answers.cfm?uuid=00060D72
0093 1B8D BCF080C4A8F00000
http://dieselplace.com/forum/forum_posts.asp?TID=10642&PN=1&TPN=4
Pages:
=> InZane XXV
