February 09, 2026, 10:54:09 AM *
Author Topic: 97 Standard Blinker issue  (Read 1128 times)
97BlkStandard
« on: September 01, 2014, 03:50:36 PM »
Ok....I have to be missing something really obvious... replaced the right rear blinker (first time, yes first one since 97) and to begin with it worked... now none of my blinkers work.  However, when I turn the blinkers to the right, the right front blinker shuts completely off and like wise with the left front.  Neither of the rear blinkers light up and either point.
3W-lonerider
Shippensburg Pa
« Reply #1 on: September 01, 2014, 04:40:30 PM »
did you install an 1156 bulb. which has one contact. or did you install an 1157 which has 2 contacts. 1156 in the rears and 1157's in the front.
97BlkStandard
« Reply #2 on: September 01, 2014, 05:01:37 PM »
I installed the 1156 and when I pulled the other rear blinker bulb it was the same as the new one. Even tried swapping sides...same result
Bone
« Reply #3 on: September 01, 2014, 05:08:44 PM »
Could there be a short that caused the first bulb failure ?
97BlkStandard
« Reply #4 on: September 01, 2014, 05:19:08 PM »
I suppose that is possible but that bulb has been in their since I purchased the bike new in 1997 so I'm guessing it's getting time to replace some of the lights.  Smiley
Michvalk
Remus, Mi
« Reply #5 on: September 01, 2014, 05:38:46 PM »
Check the ground. Start with the one from the battery to the engine block. Then check the connection under the rear fender, where the joint is to remove the fender.  cooldude
97BlkStandard
« Reply #6 on: September 01, 2014, 06:40:40 PM »
Thanks... I will try that tomorrow night.
bentwrench
Philadelphia,Pa.
« Reply #7 on: September 01, 2014, 06:43:32 PM »
Does the brake lamp still work?if not ck your fuses
97BlkStandard
« Reply #8 on: September 01, 2014, 06:51:36 PM »
I had not checked the brake lamp it does not light...just rear tail light.  I will also check the fuses.
bentwrench
Philadelphia,Pa.
« Reply #9 on: September 01, 2014, 07:47:24 PM »
P.S. the frt.markers are wired thru the t/sig. switch.they turn off when the t/sig is on
97BlkStandard
« Reply #10 on: September 02, 2014, 03:23:27 AM »
Thanks... I did not know that.   Smiley
97BlkStandard
« Reply #11 on: September 02, 2014, 09:19:30 AM »
Also, I'm going to assume that a short of some kind caused this to happen.  I'll check the grounds to make sure they are tight and if that isn't it... other ideas?
pais
One more turn should do it!
Kent, Ohio
« Reply #12 on: September 02, 2014, 05:26:01 PM »
  3-W, My right(front) turn signal was not working. Running light on but no blinker. Pulled bulb checked numbers. No luck at The Zone. Closest I could get is a 1157. Problem is that blinker(with 1157) now blinking real fast and much brighter than other. Let me mention that I pulled the properly working one out (left) side, and switched them. I know both sockets are ok. Just want to make sure about that 1157 being correct?
3W-lonerider
Shippensburg Pa
« Reply #13 on: September 03, 2014, 07:45:24 PM »
1157 should be the proper ones for the front. there should be 2 elements in the bulb and 2 nubs on the base. if the rear signal is not working the front will blink real fast.
Tailgate Tommy
Fort Collins, Colorado
« Reply #14 on: September 04, 2014, 09:23:07 AM »
If the bulbs are installed 180 degrees off, the signals will work, but flash very fast. Don't ask me how I know...
97BlkStandard
« Reply #15 on: September 08, 2014, 07:01:45 PM »
I ended up just replacing the fuse... checked the connections and everything seemed tight.  Not sure yet what caused it... Been riding it for about a week both in-town and interstate driving with no issues.
