February 09, 2026, 10:54:17 AM *
Author Topic: cobra exhaust  (Read 1367 times)
matt
Derry New Hampshire
« on: September 03, 2014, 01:26:33 PM »
Hello. I have had exhaust on bike for around 27000 miles.  Question does baffle break down wear out as I have a few pipes that are louder?    Also riding buddies say they don't like how it sounds know.  I can tell its louder but not sure how it  sounds(they say it sounds bad)  they like its louder but they say it sounds like sh**!!!!
« Reply #1 on: September 03, 2014, 01:58:34 PM »
Cobra baffles are solid steel, nothing to wear out
matt
Derry New Hampshire
« Reply #2 on: September 03, 2014, 02:54:10 PM »
Some thing changed cause it sure don't sound the same
Joevalk
Santa Fe, Texas
« Reply #3 on: September 03, 2014, 03:52:34 PM »
Make sure one didn't fall out.
VRCC#32720
1999 Grn/Silver Interstate
matt
Derry New Hampshire
« Reply #4 on: September 03, 2014, 03:55:31 PM »
Kinda funny you say that as I was just cooking g on the grill I thought same thing . Nope they are all there
« Reply #5 on: September 03, 2014, 04:34:23 PM »
The fiberglass wrap on one or 2 of the baffles might be all blown/burned out.
« Reply #6 on: September 03, 2014, 05:24:53 PM »
matt
Derry New Hampshire
« Reply #7 on: September 03, 2014, 05:59:22 PM »
That is what I was asking if they have a wrap on them (Chris) do they have a wrap on them as you stated it is just a pipe with holes
« Reply #8 on: September 03, 2014, 07:19:45 PM »
Chris is right the baffles are steel perforated pipe without glass wrapping.
My rides:
olddog1946
Moses Lake, Wa
« Reply #9 on: September 03, 2014, 07:32:04 PM »
If they were put on new they had no wrap on the baffles,,,if used, there's a good chance there was some added. I added wrap to mine, which helped a lot but not enough for me to keep the pipes on the bike for long.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
« Reply #10 on: September 03, 2014, 07:50:19 PM »
They don't come from cobra wrapped with fiberglass
matt
Derry New Hampshire
« Reply #11 on: September 03, 2014, 08:22:43 PM »
Thanks everyone. It sounds like just right side is louder.  I guess I will have to remove baffle from left and see if it is wrapped.  I don't think they are as I have had a bike that was wrapped and when it started to come apart I would see pieces coming out
« Reply #12 on: September 04, 2014, 07:35:05 AM »
If you want to wrap it yourself I'd suggest using stainless steel wool which will last indefinitely.  You can find it at Amazon.  I used it to make the custom glass/SS packs for this bike:
matt
Derry New Hampshire
« Reply #13 on: September 04, 2014, 02:15:14 PM »
Damm that is sweet Mark,  thanks for the info on wrap to use.  I wish I had the coin to get one of your systems. I keep looking at stock take off exhaust I have and dream
« Reply #14 on: September 04, 2014, 03:43:30 PM »
Beautiful work!  cooldude
My rides:
« Reply #15 on: September 04, 2014, 04:13:51 PM »
Matt: What may be happening is the vacuum lines may be wearing out causing the cylinders to be unbalanced. Replace vac lines, tighten all intake clamps and do a carb synch.
matt
Derry New Hampshire
« Reply #16 on: September 04, 2014, 04:31:47 PM »
That's what I was thinking and why I broke a bolt taking kury plug runners off so I could look at intake orings and such. I do have a Pringle  have not desmoged I do have new caps on Intake nipples
tonyfan70
Apparently they know you?
Central Illinois
« Reply #17 on: September 05, 2014, 07:08:41 AM »
Mark,
That bike looks tits. Thinking of that slowly rolling through a slightly dusty parking lot with those pipes kicking up a storm....Nice!
1997 Standard. Original bumblebee tin stored.
1998 Magna 750
2000 POS Sportsman 500
