Argon0639
« on: September 09, 2014, 09:44:45 AM » |
Hello everyone! I have a 97 Valk standard and I recently replaced my front turn signals with LED bulbs. As I figured, they now blink a million times a minute because of the load difference on the flasher module. I read in another post on here that Autozone sells a module that is LED compatible so yesterday I paid the $12 for an EP34 flasher from Autozone and attempted to install it. I found the OEM module (again thanks to this board) behind the left side cover, behind the overflow tank. I cut off the old module and installed and heat shrink tube sealed the required blade connectors on. Everything looked good except I can't get the darn thing to work. What color wires go to what on the flasher? I read someplace that the green is the ground, I think the grey goes to the lights and the black is power? Three wires, three connections. At this point thinking either the flasher is bad or it's not the correct one. Any suggestions would be welcome. The LED bulbs in the front are super bright. Especially since I used white LEDs, so I would like to keep them in if at all possible. Open to alternate solutions as well since I still have the stock flasher and could reinstall it if needed. Thanks in advance!
« Reply #1 on: September 09, 2014, 10:10:29 AM » |
I had legions of problems with LED signals (probably all ground).
Fast flashers was number one.
Took it apart many times, used an electronic flasher. Never got it exactly the way I wanted it. Would not use load equalizers which end up with the same draw as regular bulbs and get hot enough to cause wiring damage.
I would have been better off with fast flashing signals.... They are supposed to attract attention and let others know your intention to turn. What better way than to have them fast flashing, looking out of the ordinary, and attracting attention? Of course, I knew anyone in the know would understand I did not have them hooked up properly, so I kept at it, over and over. Let them be fast.
I doubt fast flashers would be cause to fail an annual safety inspection, if you have such requirement.
rhinor61
« Reply #2 on: September 09, 2014, 10:33:52 AM » |
John
Northern California 1998 Valkyrie Tourer Black/jade VRCC #28001
Argon0639
« Reply #3 on: September 09, 2014, 10:41:35 AM » |
Ordered it on Amazon. Thanks! Was looking for something that wasn't a million dollars!
« Reply #4 on: September 09, 2014, 01:33:48 PM » |
Argon0639
« Reply #6 on: September 09, 2014, 02:04:42 PM » |
I saw that and it looks awesome! I didn't want to pay the $110 though.
72cutlassdude
99 Super Valk VRCC 35563
Laingsburg, MI.
« Reply #7 on: September 09, 2014, 02:15:16 PM » |
Hey MARKT,
I have the Kissan Signal Minder on my I/S with the stock bulbs, can I swap LED's in without any issues? Thanks!
"Common sense is not a flower that grows in everyone's garden"
BobB
« Reply #8 on: September 09, 2014, 02:46:08 PM » |
I wish I would have found that two years ago when I converted to LEDs. To keep from cutting up the wiring harness, I cobbled up the OEM flasher to make a pluggable adapter to a standard flasher relay. That was a lot of work.
blackvalkyrie
« Reply #9 on: September 09, 2014, 07:28:21 PM » |
Hey argon.. I have the exact same bike n did the exact same thing..installed super bright white led for my turns.. I wired the flasher and NO flashing!! I was bummed and thought I had to buy another flasher..then I thought " what the heck" and REVERSED the wiring on the flashers... Boy was I happy when they worked!!!! So try that ... the wires came one way on the flashers but were installed backwards for a 97 valk.... Hello everyone! I have a 97 Valk standard and I recently replaced my front turn signals with LED bulbs. As I figured, they now blink a million times a minute because of the load difference on the flasher module. I read in another post on here that Autozone sells a module that is LED compatible so yesterday I paid the $12 for an EP34 flasher from Autozone and attempted to install it. I found the OEM module (again thanks to this board) behind the left side cover, behind the overflow tank. I cut off the old module and installed and heat shrink tube sealed the required blade connectors on. Everything looked good except I can't get the darn thing to work. What color wires go to what on the flasher? I read someplace that the green is the ground, I think the grey goes to the lights and the black is power? Three wires, three connections. At this point thinking either the flasher is bad or it's not the correct one. Any suggestions would be welcome. The LED bulbs in the front are super bright. Especially since I used white LEDs, so I would like to keep them in if at all possible. Open to alternate solutions as well since I still have the stock flasher and could reinstall it if needed. Thanks in advance!
Argon0639
« Reply #10 on: September 09, 2014, 07:39:01 PM » |
I wish that would've worked! I hooked that stupid thing up every way imaginable. Lol! I do love the super bright running lights and signals though. Replaced my tail light as well. Thanks for the response guys!!
Argon0639
« Reply #11 on: September 16, 2014, 05:11:05 AM » |
Turned out the fuse for the turn signals had blown. Must have touched wires or something. In any case, replaced the fuse and the Autozone flasher works great. The other flasher works well too. I'll probably use the extra flasher to put in hazards. Lol. Def doesn't take much to blow those fuses! At least now I have spares! Thanks for all the help.
« Reply #12 on: September 16, 2014, 10:54:30 AM » |
Hey MARKT,
I did that but I have an early model signal minder. I have LEDs in back and tungsten in front. Recently re-installed the back seat so i made a custom Highlighter for me that has 54 LEDs, wired in as run brake and turn. No problem for the Kisan. I'm guessing no problem for later models as well.
« Last Edit: September 17, 2014, 04:19:07 PM by MarkT »
« Reply #13 on: September 16, 2014, 04:21:02 PM » |
Really nice job Mark.  I have always thought that lights up on the sissy is a great idea..... like are up high on most cars, trucks and SUVs these days.
« Reply #14 on: September 17, 2014, 12:39:08 PM » |
Well, that would do it. Fuses with a hole in the middle don't work well. And you're right, it doesn't take too much to blow them, thats their job.
« Reply #15 on: September 17, 2014, 12:40:08 PM » |
Hey MARKT,
I did that but I have an early model signal minder. I have LEDs in back and tungsten in front. Recently re-installed the back seat so i made a custom Highlighter for me that has 54 LEDs, wired in as run brake and turn. No problem for the Kisan. I'm guessing no problem for later models as well. PPT HighlighterThats a slick idea. Looks good too.
pais
One more turn should do it!
Kent, Ohio
« Reply #16 on: September 20, 2014, 03:56:24 AM » |
Custom job on the back of the passenger back rest  !! Does that Kisantech unit work well with no problems? It interests me a great deal. I don't like to mess with the electrics if I don't have to. That device seems to have some really useful, good features. Are you happy with the performance and was the install that simple?
72cutlassdude
Laingsburg, MI.
« Reply #17 on: September 21, 2014, 05:52:20 AM » |
PAIS,
I installed mine almost two years ago and couldn't be happier with it! It is a pretty straight forward install, just follow the directions. I set up all the options, the only modification I made was to cut 1 wind off the springs that go in the turn signal switch. Now all I have to do is figure out how to replace the turn signal indicator bulbs to LED, the incandescent bulbs now stay on dimly lit all of the time.
blackvalkyrie
« Reply #18 on: September 28, 2014, 06:31:09 PM » |
so glad it worked ouot  those led's are awesome  Turned out the fuse for the turn signals had blown. Must have touched wires or something. In any case, replaced the fuse and the Autozone flasher works great. The other flasher works well too. I'll probably use the extra flasher to put in hazards. Lol. Def doesn't take much to blow those fuses! At least now I have spares! Thanks for all the help.
DK
« Reply #19 on: November 06, 2014, 02:17:27 PM » |
I installed LED front & rear turn signal lights with the Signal Minder & it works great. The SM is well worth the price for safety alone.
Got the LED's @ Auto Zone.
