November 26, 2025, 04:23:48 AM *
Author Topic: Quick release Tour Pack  (Read 1881 times)
Hox
« on: September 23, 2014, 09:02:38 PM »
Anyone know if the Harley Quick Release system from Harley can be modified to fit Valk Interstate... or other quick release options... thanks,   Hox
« Reply #1 on: September 24, 2014, 05:00:26 AM »
You could just Super-Valk yours and save a ton of money.
Hopester
Geneva, Illinois
« Reply #2 on: September 24, 2014, 05:13:30 AM »
I super valked my Interstate.  It literally takes 5 minutes to remove the trunk.
« Reply #3 on: September 24, 2014, 08:15:21 AM »
You remove the tail light and brake lights when you remove the trunk from the Interstate.
« Reply #4 on: September 24, 2014, 08:30:15 AM »
I'm pretty sure that's why most people add the tail light from the Standard or Tourer to their Interstate.
jwinker
St. Paul, MN, USA
« Reply #5 on: September 24, 2014, 05:41:13 PM »
Speaking of...
Are there any good guides for making a Super-Valk, offhand? I've tried searching on here, but not finding much.
Like the OP, I'd like to do a quick-release on the trunk with a tail/brake lamp of some sort down below. Is a Std/Tour lamp the best bet, or has anybody used something different (Kury/HD/Etc)? Anything that has been tried and failed?
« Reply #6 on: September 24, 2014, 06:14:17 PM »
There are some posts here somewhere about how to do it with very detailed instructions.
As far as tail light a standard would be easiest because the rear fender already has a factory hole for mounting the standard/tourer taillight.
jwinker
St. Paul, MN, USA
« Reply #7 on: September 25, 2014, 05:50:24 AM »
To the OP, I did some more searching and found a photo site with step-by-step pictures on an inexpensive removable trunk. It's not quite as fast as an HD quick-release, but I'm guessing it's 10% of the price.
http://bigbf.com/bigbf_shop/mod_i-s_trunk/
« Reply #8 on: September 25, 2014, 04:40:49 PM »
Less than 10% all you need is a tail light  and to wire it into existing harness.
« Last Edit: September 25, 2014, 05:57:44 PM by Bighead » Logged
jwinker
St. Paul, MN, USA
« Reply #9 on: September 25, 2014, 04:58:42 PM »
Search works much better when you hyphenate "Super-Valk"  Grin
