January 29, 2026, 10:17:03 AM *
Author Topic: 5.529 gal. to fill up  (Read 1686 times)
hueco
WACO,TEXAS
« on: August 13, 2009, 12:58:02 PM »
That is 28.341 mpg. Conservative riding. It was getting 34+ then it just dropped. Replaced vaccum hoses. They where bad. No help. Still runs as great as always. Fuel milage just took a dump. Set the pilots and calibrate?  And see what happens? Thanks.
« Last Edit: August 13, 2009, 12:59:41 PM by hueco » Logged
Black Dog
VRCC # 7111
Merton Wisconsin 53029
« Reply #1 on: August 13, 2009, 01:02:35 PM »
Check your intake runners...  Between the carbs and the metal runner, is a rubber tube, with two hose clamps, one on the carb end, and one on the runner end.  They do get lose.  Also look for signs of intake 'O' ring leaks, where the runners meet the heads.  A quick way to check if they are leaking, is to spray some carb cleaner right at the base of the runners, while the engine is running.  Any change in RPM, or a puff of white smoke, and you've found a leak.
Happy hunting.
Black Dog
Don't you know...
