November 26, 2025, 04:55:48 AM *
Author Topic: cb won't power up  (Read 774 times)
horn5390
murfreesboro tenn
« on: November 04, 2014, 06:58:22 AM »
my cb will not power up on command from the power switch. the display says ''Er'' meaning error. it has been working since I bought the bike but now acting sketchy. Sometimes it will turn on, mostly 50/50 chance. I have confirmed power from the white 3 wire plug under the right side cover. I'm assuming this plug is the main power lead. Previous owner had installed the cb in the tray behind the battery, so not sure about his mechanical skills. could there be a bad ground somewhere I don't see or just some electrical corrosion on the power plug?
if you aint had to lay her down, you don't ride enough
mustang071965
those that dare, Succeed.
monticello Ar
« Reply #1 on: November 04, 2014, 07:09:48 AM »
had the same issue once with mine. took of the drivers seat and found the control wire to the c b unit loose. unpluged and repluged the control wire and it solved my problem. i then taped the two halfs togeather with electrical tape to insure they would not pull apart.
« Reply #2 on: November 04, 2014, 07:41:28 PM »
I believe Dag's site has the install manual. Get it and check your connections, unplug and plug back in.
3W-lonerider
Shippensburg Pa
« Reply #3 on: November 05, 2014, 12:59:01 PM »
most of the time when I get that er message. it's the big connector that connects the cb to the radio.
I just unplug it and plug it back in and that takes care of it for awhile.
usually happens once a year
Sourdough
Tucson
« Reply #4 on: November 05, 2014, 02:34:34 PM »
take a look at this thread; might be your problem....
http://www.valkyrieforum.com/bbs/index.php/topic,25289.0.html
01 I/S Black/Beige
97 Standard Bumblebee
horn5390
murfreesboro tenn
« Reply #5 on: November 07, 2014, 07:39:55 AM »
Okay, I got it stay on for now. I took the white 3 wire connector apart, scratched the terminal wires clean. Applied some dielectric insulating grease and plugged it back together. So far it has not given me that "Er" message on the dash. See how long this will last.
