N0tac0p
« on: November 10, 2014, 06:21:32 AM » |
i have one and need to change the oil as teh lift slowly lowers itself, therefore dangerous. looking at tha manual one page calls the screw at the bottom of the chamber the drain plug another page, the fill plug. I suppose it can be both, but i could not get oil back into it. (now a question, do i need to remove a rubber o-ring inside?) any help would be greatly appreciated
wingrider02
« Reply #1 on: November 10, 2014, 06:32:19 AM » |
I just purchased a Sears lift, and had to purge the air from it. The plug at the bottom of the "jack" is the drain. The fill or vent is about half to 3/4 the way up the side.
slider
« Reply #2 on: November 10, 2014, 06:50:47 AM » |
I bought one and it had no oil in it,filled it up purged it and works great...was told that they tend to lose some oil dubeering use.works great on the bee.
a proud navy veteran
N0tac0p
« Reply #3 on: November 10, 2014, 06:52:32 AM » |
thanks guys, i'll take a look for hte second plug
« Reply #4 on: November 10, 2014, 07:33:35 AM » |
I have the yellow H/F M/C lift and it has safety stops at various heights. Whether my Lady is on the lift for 10 mins or 10 days it is lowered to a safety stop. Hope you get it repaired correctly. RIDE SAFE.
« Reply #5 on: November 10, 2014, 08:01:28 AM » |
I lift my bike up barely off the ground, not all the way to one of the stops.
It will definitely leak down, and your bike will fall off if you don't take precautions...
I jamb a board in the scissors when I put mine on the jack, it has stayed up for weeks with no problem many times...
« Last Edit: November 10, 2014, 10:04:23 AM by hubcapsc »
WDAN
« Reply #6 on: November 10, 2014, 08:15:05 AM » |
I have a Harley Davidson mechanical lift. No worries about hydraulic failure
WDAN Irving, TX
Bone
« Reply #7 on: November 10, 2014, 09:41:35 AM » |
My Sears lift started to leak down about the 3rd year. Decided it was time to read the instruction booklet that came with the jack. It tells us to change the oil once a year. I found some jack oil at Autozone our town lost it's Sears store. If I travel in the winter I adjust a jack stand to fit loosely under the bike for piece of mind.
N0tac0p
« Reply #8 on: November 11, 2014, 02:47:43 AM » |
YUP, thats the key, change the oil as it gets aereated, dirty and simply breaksdown.
gregk
Retired
Chippewa Falls, wi.
« Reply #9 on: November 11, 2014, 02:39:57 PM » |
I'm going to be looking at one but I cant believe it all, they sound like junk. I have a verticle (5 ton ?)jacki think that i bought in the middle 70's that has never had a problem. probebly was a farm & fleet.
« Reply #10 on: November 11, 2014, 02:52:57 PM » |
The one you bought in the 70's more than likely is AMERICAN Made. And the ones you will find today will be made somewhere in Asia
« Reply #11 on: November 12, 2014, 04:35:30 PM » |
About the same for me also. Replaced with fresh jack oil and it got a lot better. Still bleeds down a tad, but it's usable as it is now. Before, it bleed down almost as fast as I could pump the peddle.
I can't help about the shape I'm in I can't sing, I ain't pretty and my legs are thin But don't ask me what I think of you I might not give the answer that you want me to
N0tac0p
« Reply #12 on: November 17, 2014, 04:54:13 AM » |
INTERESTINGLY, my Sears Jack DOES NOT have an upper fill hole. where they DO show a phillips head screw in later pics, mine has none.
figure 2 of hte manual indicates the "fill hole" as also the "drain hole".......well i took out the components ( check ball, etc) hoping oil would go into the cylinder... no such luck.
Apparently my model 90150 is a throw away??? anyone have experience with this?
should i just buy a pitbull lift?
