February 09, 2026, 04:59:32 PM *
Author Topic: petcock question  (Read 997 times)
NewValker
VRCC# 36356
Oxford, MA
« on: November 15, 2014, 04:33:40 PM »
Hi all,  When I got the valk running after sitting 7 years, we had to replace the screen & pick-up tube.
Also  the mechanic that did it took it all apart and cleaned it and made sure it worked.
So, here's the funny thing, twice now I've taken off and rode more than 50 miles with the dial on off.
BUT, if I just let it idle, it'll stall out unless I turn the gas on. We ordered a new one that came in damaged, so back it went. Mechanic cleaned the original again, and said he couldn't see anything wrong with it.
Are we missing something here? Think I'm ready to order another new one just for piece of mind.
thanks, Craig
Turns out not what or where,
big poppa pump
San Antonio, TX
« Reply #1 on: November 15, 2014, 06:45:06 PM »
If you're able to ride 50 miles with the Petcock dial turned to Off, something just ain't right. You shouldn't be getting any gas to the bike, period! Did your mechanic open the petcock and check the innards, especially the diaphragm?
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
pancho
Bonanza Arkansas
« Reply #2 on: November 15, 2014, 06:48:27 PM »
Go for the peace of mind and be done with it...........
NewValker
VRCC# 36356
Oxford, MA
« Reply #3 on: November 15, 2014, 07:23:06 PM »
Yes, he did take it apart, he got a rebuild kit for it instead of new at the time, the diaphram is new.
He specializes in wings and valks, and he had never had one do this before. Guess I should have gone new but I was short on cash and he saw no reason a kit wouldn't do the job.
thanks again,
Craig
« Reply #4 on: November 15, 2014, 07:39:44 PM »
There have been reports of the same thing happening. Most have come to the conclusion that you didn't have the ball indent actually in the off position, therefore the petcock was still turned on allowing fuel to flow.
This kind of multiple repairs doesn't sound right. Save your money and check some other things yourself.
A lot will come back and say to change the petcock out to a mechanical one from the OEM Honda one.
Check out this link showing the parts.
http://www.valkyrieforum.com/bbs/index.php/topic,37063.0.html
« Last Edit: November 15, 2014, 07:46:51 PM by gordonv » Logged
« Reply #5 on: November 15, 2014, 09:03:29 PM »
BPP I like what you have done to the scoot cooldude
big poppa pump
San Antonio, TX
« Reply #6 on: November 15, 2014, 09:07:56 PM »
Thank you. TBH...your bike provided the inspiration. Love how your Valk looks in yellow.
VRCC#35870
VRCCDS#0266
NewValker
VRCC# 36356
Oxford, MA
« Reply #7 on: November 18, 2014, 01:10:36 PM »
Thanks everyone for the replies. I've noticed when I turn the gas off from the ON position, it's directly at 9 o'clock. If I turn it off from RESERVE position, the knob is slightly higher, more like 10 o'clock.  dunno???  I can hear and feel it click into the position either way.
Thanks gordonv, good reading in that link.
Craig
Michvalk
Remus, Mi
« Reply #8 on: November 18, 2014, 01:21:40 PM »
If you can ride 50 miles with the petcock off, and it dies at idle, you have the beginnings of hydrolock. I would replace the petcock as soon as possible. The dying at idle could be low vacuum, caused by a cracked vacuum line or a bad o-ring on the intake. Somewhere there are two problems, and you don't want a hydrolock under any circumstances. cooldude
