February 09, 2026, 04:57:12 PM *
Author Topic: Noob question about throttle assembly  (Read 830 times)
big poppa pump
San Antonio, TX
« on: December 10, 2014, 03:16:41 PM »
Trying to adjust the throttle slack and I have somewhat of a noob question. Looking at the carb bank from the right side of the bike, is the pull cable supposed to be attached to the carb bank to the back or the front or does it make no difference at all which cable goes where?  Embarrassed
Thanks.
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
« Reply #1 on: December 10, 2014, 04:13:07 PM »
There are 2 cables. One is when you release the throttle it springs back and the other is the throttle cable. I believe the one that springs back is the rear one (the one more toward the center of the bike). Hope this makes sense.
big poppa pump
San Antonio, TX
« Reply #2 on: December 10, 2014, 04:29:52 PM »
There are 2 cables. One is when you release the throttle it springs back (PUSH) and the other is the throttle cable (PULL). I believe the one that springs back is the rear one (the one more toward the center of the bike). Hope this makes sense.
PUSH = rear
PULL = front
VRCC#35870
VRCCDS#0266
« Reply #3 on: December 10, 2014, 05:11:58 PM »
Believe you got it  cooldude
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #4 on: December 11, 2014, 05:37:29 AM »
you can adjust the inside cable to take up the slack. The outside cable is not adjustable
big poppa pump
San Antonio, TX
« Reply #5 on: December 11, 2014, 06:44:57 AM »
Finally got it done last night. Thanks everyone for your help.
VRCC#35870
VRCCDS#0266
