February 09, 2026, 04:59:28 PM *
Author Topic: Replacing RAGNAR cut pipes.  (Read 1846 times)
« on: December 14, 2014, 07:35:24 AM »
I've got a Gyrl with a set on RAGNAR cut pipes and truck stacks.
It sounds good, but I find myself not riding her as much as I should because of the drone and the noise I cause to my neighborhood.  I usually just idle around near my house, but the noise just gets to me.  One of the things I always loved about Valks is stealthiness.
My question (s) is , the bike has a K&N filter, RAGNAR cut and was supposedly jetted by Goody, if I install OEM pipes, should I be concerned about the jetting.
My feeling is re-jetting is done for, or because of, the change of the air intake and exhaust makes no difference.
Is that right?
« Reply #1 on: December 14, 2014, 08:21:10 AM »
P M Attic Rat-he WILL have your answer. RIDE SAFE.
« Reply #2 on: December 14, 2014, 09:41:10 AM »
So what change has been made to the intake ? That K&N doesn't care.
I don't think any jetting was needed, so, putting it back to original should be fine.
A set of original pipes are expensive aren't they ?
« Reply #3 on: December 14, 2014, 09:44:33 AM »
I agree!  cooldude I found a set of OEM exhaust for $300, however the piggies were cut off, be careful.
My rides:
« Reply #4 on: December 14, 2014, 10:03:50 AM »
OEM exhausts described as really good take-offs were posted on the Classifieds last night... they might
still be available...
« Reply #5 on: December 14, 2014, 12:29:08 PM »
Actually, I have a set of OEM's I took off my third Valk cause they are somewhat corroded.  The PO would ride around Long Island in the salt air and throw a tarp over her when he got home.
Gonna paint them black and put them on and get use to them.  I got new tins and tips to put on, so they should look pretty good.  Good enough, any ways.
I got a good set out of FL for $150 with the piggies back then.
Good idea, I'll pm Bob later, thanks.
« Reply #6 on: December 14, 2014, 03:01:48 PM »
I fixed my ragnar exhaust with a set of these.....
http://shopping.rexmar.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=silencers-inline-insert
And a set of Grumpy tips.  Drone gone.  Sounds great with a nice deep growl without all of the noise.
« Reply #7 on: December 14, 2014, 03:29:11 PM »
I like that suggestion.  Do you NEED the Grumpy tips?  I like the look of them but my truck stacks are slash cut, I didn't think Grumpy's tips would work with them?
« Reply #8 on: December 14, 2014, 05:37:24 PM »
No.  But they do dress up the rear of the exhaust tips really nice.
However, that said, and regarding drone.....drone is the exhaust resonating inside the exhaust tip/can on the way out to the back of the exhaust.  That's why mother Honda put the piggies on there in the first place....to get that exhaust out to the back of the exhaust tip so that it wouldn't resonate in there.
Anything that you can add to break up that resonance helps to reduce, or eliminate drone.  A set of Grumpy tips helps in that regard.
97BLKVALK
VRCC#26021
Detroit Lakes, MN
« Reply #9 on: December 16, 2014, 06:30:51 PM »
Hook,
Check with Mark T  www.horseapple.com   He has a couple ways to handle this issue.
You can purchase piggies and use an exhaust adhesive and a couple screws to end the drone.
Or send your exhaust to him and have it modified so you can have it mild or wild.
Michael
http://www.horseapple.com/Valkyrie/Valk_Products/M2W_Exhaust__System/m2w_exhaust__system.html
1997 GL1500C - Black
1997 GL1500C - Purple
1997 GL1500C - Bumble Bee
1998 GL1500C - Blue and Cream
« Reply #10 on: December 17, 2014, 02:40:48 AM »
Hook,
Michael
Hey Michael ,  thanks for the suggestion, I didn't consider that, but will now.
O-B-1
Vancouver, WA
« Reply #11 on: December 18, 2014, 06:52:54 PM »
+1  cooldude And mine isn't all that loud with them in...
David W. Mitchell
1999 Honda Valkyrie GL1500C
